20 Most Recent
Yamaha 2005 RS Venture Questions & Answers
Replacing starter
The Starter is located forward of the Engine, Left side. Make sure you disconnect the Battery BEFORE you start working on the starter.
Tighten track
NEVER OVERTIGHTEN a track.
Raise the Rear of the Track off the ground
Align the openings of the Track to gain access to the Adjustment screws
Loosen the Jam Nuts
CW to Tighten (make sure you do it evenly on both sides)
Did I mention NEVER OVERTIGHTEN a Track
Inspect your Sliders, right now is a good time to change them out if they are worn and the reason for the track being loose.
Battery keeps losing charge
Sounds like you either have a Bad Battery or your Coil broke a wire for the charging system.. Do your Lights work when it is running
Track noise
Inspect all picks for rips.wiggle all wheels,inspect slide rails and limitor straps.
10/2/2014 5:02:39 PM •
Yamaha RS...
Answered
on Oct 02, 2014
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
