20 Most Recent Olympus FE-25 Digital Camera Questions & Answers
0answers
5answers
What is the best free
First of all, do not save any new file to camera's memory card.Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.You can then recover photos from camera by downloading this photo recovery softwarehttp://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Photo-Recovery.shtmlInstall and open the photo recovery software, select the memory card, and click 'Start' button.
1/10/2014 1:59:04 AM • Olympus FE-25... • Answered on Jan 10, 2014
Shutter frozen shut but makes noise did not drop. 10 min prior took pics
The shutter motor gear linkages are seized, the lens assemble will need to be dismantled for repair.
5/28/2012 10:24:00 PM • Olympus FE-25... • Answered on May 28, 2012
No sound on my videos,
YOU GO TO MENU AND FIND THE SOUND AND PRESS ON
8/16/2011 9:02:30 AM • Olympus FE-25... • Answered on Aug 16, 2011
How can you fix the sound in a camera
Here is the owner's manual, perhaps you can find a solution here.
http://www.olympusamerica.com/files/FE-25_X-20_Instruction_Manual_EN.pdf
7/30/2011 5:41:52 PM • Olympus FE-25... • Answered on Jul 30, 2011
I lost software to operate
You can download Olympus software from
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1436
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
7/1/2011 5:12:01 PM • Olympus FE-25... • Answered on Jul 01, 2011
I lost software and its
You can use Olympus Master 2 with your camera to download photots and edit them ect. This is availabel for free from their consumer website. Here is a link to the download:
http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp
6/20/2011 5:17:14 PM • Olympus FE-25... • Answered on Jun 20, 2011
2answers
Camera lens is frozen in open position.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/17/2011 3:30:22 AM • Olympus FE-25... • Answered on Mar 17, 2011
My olympus FE-25 doesn't record sound why? and can
This camera does not support sound recording.
3/8/2011 12:27:59 AM • Olympus FE-25... • Answered on Mar 08, 2011
I download clips i did with the camera to the
There is a review of this camera at:
This link
that says the video clips are recorded without sound. If you need sound you will have to use a camera that has the capability.
You can download a manual for the camera here.
10/18/2010 7:59:37 PM • Olympus FE-25... • Answered on Oct 18, 2010
Nimh batteries give low batt signal even when
the trouble with rechargable batteries is their voltage is low to start with even when charged. they only give 1.2 volts each instead of 1.5 volts from proper AA bateries. I use Energizer Lithiums in all my camers and they are great and last a long time. You can find cheap suppliers on eBay I use a site called 7dayshop.com in jersey (europe).
7/25/2010 10:44:58 PM • Olympus FE-25... • Answered on Jul 25, 2010
How do I change the megapixels
If you right-click the picture file and then click on e-mail, you will be presented with choices of picture size. Choose one and it will open your e-mail with the pic attached, ready to mail. Your original pic remains untouched.
7/2/2010 7:54:36 PM • Olympus FE-25... • Answered on Jul 02, 2010
In my camara when i start message shows
Having gone over a month with no response, I assume this is no longer a problem.
6/21/2010 7:18:26 PM • Olympus FE-25... • Answered on Jun 21, 2010
Can not make camera work.put in 3 sets of new
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.b09ae5c.jpg
4/3/2010 6:39:02 PM • Olympus FE-25... • Answered on Apr 03, 2010
When i try and turn on my olympus camera it makes
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
2/25/2010 12:48:18 AM • Olympus FE-25... • Answered on Feb 25, 2010
The camera says xd and sd compatible but it seems
The camera has one xD slot, and is supplied with an adapter which fits into the slot if you wish to use micro-SD cards. Regular SD and mini-SD cards will not fit.
7/2/2009 4:35:16 PM • Olympus FE-25... • Answered on Jul 02, 2009
Can't hear audio on video playback (neither direct from camera nor from pc)
This is because the camera is not capable to record the sound. The camera was not designed with any audio speakers to be able to record and playback sound recorded during movie mode.
4/27/2009 12:38:08 PM • Olympus FE-25... • Answered on Apr 27, 2009
Olympus FE-25 Digital Camera Logo
21 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
best free
  • Cameras
