20 Most Recent Zanussi ZWF14070 Front Load Washer Questions & Answers
Door will not open after cycle finishes
I had similar problem, but never found the cause, ended up spinning washing again and again until I could open door. Control system replacements are expensive , almost as much as a new machine.
5/2/2022 4:51:58 PM • Zanussi ZWF14070... • Answered on May 02, 2022
A wash machine is not responding at all. the start/pause button keep flashing green
door lock problem or water inlet blocked
7/19/2014 9:53:51 PM • Zanussi ZWF14070... • Answered on Jul 19, 2014
The washing machine works ok & cycles but the
HI,
IM LEO
MAKE SURE THE HOSES ARE ATTACHED TO THE RIGHT INLET IN THE BACK OF WASHER
PUT EA. HOSE OVER IN THE WASHER AND TURN ON THE WATER TO MAKE SURE EA.
HAS THE RIGHT VOLUME
IF THEY DO THEN YOU KNOW THE WATER IS GETTING TO THE MIXER VALVE
THEN YOU HAVE TO REPLACE THE MIXER VALVE. (THAT'S WHAT THEY SCREW ON)
THIS IS THE MOST COMMON SOLUTION. THERE ARE OTHERS THAT ARE A LITTLE MORE COMPLICATED LIKE THE WATER LEVEL SWITCH IN THE CONSOLE.
Thank you for using fixya
Leo Ponder
imufo2
Please rate me if this helped.
8/13/2011 10:03:50 PM • Zanussi ZWF14070... • Answered on Aug 13, 2011
Hi,our washing machine will not
Make sure that the door switch is working - if this wont work then the program controller unit will not be initiated to start.
If this seems OK with a test that the switch is contacting and the wires are intact to the program controller, the we need to suspect the main-controller unit. Check all wires to check if there is any break.
2/4/2011 12:40:58 PM • Zanussi ZWF14070... • Answered on Feb 04, 2011
Washing machine wont spin unless i stop and put it
Has the water gone out completely? if it has then i suspect your pressure pipe is blocked. if not clean filter
8/11/2010 1:04:30 PM • Zanussi ZWF14070... • Answered on Aug 11, 2010
Can you please give me
Disconnect power to the machine then open the pump door on the bottom right hand side of the machine after making sure the water, if there's any, has cooled down. Place a container close to the pump to collect any residual water from the pump then pull out the emergency emptying hose, if available on your machine, and place it in the container and remove its cap.
Unscrew the pump filter and remove it when no more water comes out of the emergency emptying hose. It is a good idea to keep a rag or a towel nearby to dry up any water spillage when removing the filter. Clean the filter and remove any objects from the pump impeller by rotating it. Make sure to put the cap back into the emergency emptying hose before putting it back into position into the cabinet. Screw the pump filter into place and close the pump door.
7/18/2010 11:36:20 AM • Zanussi ZWF14070... • Answered on Jul 18, 2010
Zanussi Washing Machine - ZWF 14070W1 - Door Lock
If there is water still in the drum,try draining it out with the emergency drain hose down by the filter,then take out the filter bung by turning anti-clockwise and pull out to see what has got stuck in the pump.After this is cleared the door should open and the machine should be ready to run again.
Hope this helps.
5/25/2010 8:48:47 AM • Zanussi ZWF14070... • Answered on May 25, 2010
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
3/31/2010 5:47:52 PM • Zanussi ZWF14070... • Answered on Mar 31, 2010
Zanussi ZWF14070 - concrete 'damper'
Moulded plastic 'spigots' still form part of the drum housing, but no concrete block is now fitted to the rear.
11/17/2009 9:22:31 AM • Zanussi ZWF14070... • Answered on Nov 17, 2009
Loud banging noise on spin cycle
something is loose, i would take apart and check for loose objects, or call a pro to do it for you., it can be a tedious job.
11/6/2009 7:03:48 PM • Zanussi ZWF14070... • Answered on Nov 06, 2009
Need dimension of Zanussi Aqua cycle 400
1/4/2024 9:07:00 PM • Zanussi Washing... • Answered on Jan 04, 2024
Zanussi Washer dryer ignoring all programs and just does a pulsing humming sound (Only works well on reset mode)
It seems like you've done a thorough job troubleshooting so far. The E69 error could be related to a heating issue. Since you've already replaced the heating element, it's worth checking the thermal fuse. The thermal fuse is a safety device that can sometimes cause E69 errors if it's faulty. Given that you have access to a spare machine, you might consider swapping the thermal fuse from the spare machine to see if it resolves the E69 error on your primary machine. If the spare machine's thermal fuse is in good condition, it could be a step toward identifying and solving the issue without having to switch the drums. Remember to disconnect the power source before attempting any replacements, and I hope this helps you get your tumble dryer back in working order.
12/5/2023 9:07:17 PM • Zanussi Washing... • Answered on Dec 05, 2023
Zanussi ZWF1640 - at start of wash, all the lights go off and it jumps to end of cycle
May try resetting the breaker turning off turn on
9/1/2023 7:50:24 PM • Zanussi Washing... • Answered on Sep 01, 2023
Zanussi ZWF1021W Washing Machine bearing replacement?
Take a look at the videos. You will need a bearing and seal kit, plus some grease. You can knock the old bearing out using a large socket on an extension bar. That is also useful for gently seating the seal without damaging it. https://www.google.com/search?q=Zanussi+ZWF1021W+Washing+Machine+bearing+replacement Later machines have the bearings bonded to the drum. Truly a bad idea! https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/washing-machine-help-forum/31703-zanussi-zwf1431w-bearing-replacement ..
7/28/2023 4:03:25 PM • Zanussi Washing... • Answered on Jul 28, 2023
Zanussi washing machine door seal metal wire ring has come off, how do I put it back?
To put back the metal wire ring on the door seal of your Zanussi washing machine, you can follow these steps: Ensure safety: Before starting any repair work, make sure the washing machine is unplugged from the power source to avoid any accidents. Locate the groove: Examine the door seal and locate the groove where the metal wire ring needs to be inserted. The wire ring typically fits into a groove on the inner edge of the seal. Position the wire ring: Take the wire ring and position it in your hands so that it forms a complete circle. Make sure the ends of the wire are close together. Start at the top: Begin by inserting one end of the wire ring into the groove at the top of the door seal. Apply gentle pressure and work your way around, pushing the wire into the groove. Use your fingers or pliers: Depending on the size and tightness of the wire ring, you may be able to push it into the groove using your fingers. If it's difficult to do so, you can carefully use a pair of pliers to assist you. Be cautious not to damage the wire or the door seal during this process. Continue around the seal: Slowly and steadily work your way around the door seal, pushing the wire ring into the groove. Take your time to ensure that the wire is securely in place and properly seated within the groove. Double-check the installation: Once you've inserted the entire wire ring into the groove, double-check that it is evenly positioned and properly seated. Ensure that it's securely holding the door seal in place. I'm Sophia and CEO of Homyclean, and I love sharing my amazing cleaning, laundry, bathroom, best washing machine cleaners and maintenance experiences with you. I'll share hassle-free methods and top-notch products for washing and cleaning, fueling your passion for cleanliness. By following these steps, you should be able to successfully put the metal wire ring back on the door seal of your Zanussi washing machine. If you encounter any difficulties or the wire ring doesn't fit properly, it's advisable to consult the manufacturer's manual or seek assistance from a professional technician.
7/2/2023 5:45:55 AM • Zanussi Washing... • Answered on Jul 02, 2023
Zanussi ZWF14070 Front Load Washer Logo
Popular Tags
23 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
loud banging noise spin cycle
  • Washing Machines
