20 Most Recent
Samsung Memoir SGH-T929 Cell Phone Questions & Answers
D:my phone just wont turn on please help me im going insane :(
First of all please indicate the mode or phone unit next time. Here's my tip have you pressed the power button longer than 24 seconds? If you have and it still not turning on try it while the charger is plugged with it. If it still not turning on then contact the companies technical team department so they can assist you if your unit still have warranty you can exchange the unit to them for a brand new or refurbished one.
How do i put a phone lock password on my samsung
The Security feature enables you to restrict the use of your phone by others and to restrict the types of calls.
Various codes and passwords are used to protect the features of your phone.
1. From Idle mode, touch Menu ➔ Settings ➔ Phone settings.
2. Touch Security.
Lock Phone
When the Lock Phone feature is enabled, the phone is locked and you must enter the 4- to 8-digit phone password
each time the phone is switched on.
To change the phone password, refer to the next section.
Once you enter the correct password, you can use the phone until you switch it off.
1. Touch On or Off from the Lock phone field.
Change Phone Password
The Change password feature allows you to change your current phone password to a new one. You must enter the
current password before you can specify a new one.
Once you have entered a new password, you are asked to confirm it by entering it again.
1. Touch the Change phone password field.
2. Enter the current password and touch Confirm..
3. Enter a new password in the New password field and touch Confirm..
4. Enter the new password again and touch Confirm.
The password changed confirmation displays.
Note: If you change your password, be sure to write it down and keep it in a safe place. If you forget your password, your phone requires
service to have it unlocked.
Free unlock code
Unlock codes for your Samsung Memoir can be got by visiting SuperUnlockCodes.com where you need to mention your network and country your phone is locked to...They provide you with unlock code and free unlocking instructions....
For your information getting unlock codes for free may not unlock it permanently....
http://www.superunlockcodes.com/samsung-memoir/rs12wp9/
Unlock code
If you want "Network Unlock Code" for Samsung T929 Memoir mobile visit the site
WickedUnlock.com here they are providing this code at low cost with easy step by step unlocking instructions and unlock it.This is the safe,fast and permanent unlocking method.
My samsung sgh t929's touch
Mobile touch screen problems solution :
1- First: Reinstall the mobile FIRMWARE ,most of mobiles touch screen problems solved by
reinstall the mobile FIRMWARE.
2-If the reinstallation of the mobile FIRMWARE didnt solve the problem that means the touchscreen
needs to be changed.
Free unlock code
For this Samsung model free unlock code is not possible to get.You need to pay to get unlock code.Visit the site
Unlocking4u.com get unlock code for Samsung SGH T929 Memoir at low cost and unlock it easily.
Free unlock code
Do you mean the network unlock?You can get the unique unlock code for your Samsung Memoir SGH-T929 Cell Phone from
Onlinegsmunlock.com and remove the network lock easily by specifying the country and network to which the mobile is locked to.
Network lock
Hi, You can get the unlock code for a T-Mobile network locked Samsung SGH-T929 Memoir from
www.superunlockcodes.com at affordable cost with easy unlocking guide. Good luck mate.
Unlock Samsung SGH C450
Greetings !!!If you need to unlock Samsung SGH C450,You can do it from Mobile Unlock Solutions
www.mobileunlocksolutions.com for which you have to provide country which country,network it is currently locked,imei number,get code and unlock it.
How can i unlock samsung t 929 network
Hi, You can unlock your Samsung SGH-T929 Memoir from its network using unlock codes. You can get the unlock code either from your service provider or from online sites.Try
Superunlockcodes.com , they provide codes at affordable price with simple unlocking instructions.
