20 Most Recent
Motorola Mobility Motorazr2 V9x Cell Phone Questions & Answers
Calendar alert does not ring when event is planned
Good morning to youIjust know onething about setting alarms and that is. To do it in the right order. When I set mine (nokia)firstly I find software in software there is a clock. New alert- alerts- world clockI click on new alert then on the screen fill in what is asked.I can also do this trough the calender- check if this works for you..also check if alarm sound is on if not put it on.all the bestKolbrun
2/24/2012 7:18:41 AM •
Motorola...
Answered
on Feb 24, 2012
I have a Motorazar2 V9X. My phone will not
Try removing the battery and cleaning the battery contacts on the handset and battery with a pencil eraser and with 90% rubbing alcohol using a medium toothbrush. Also check the charger with another phone to see if it is good. If it still does not charge, replace the battery. If you know someone with the same type battery you might exchange batteries.
3/25/2011 2:20:46 AM •
Motorola...
Answered
on Mar 25, 2011
How do I get the
You need to get the internet settings from your service provider, enter them into the phone and set it to use them.
Please get the settings from your provider and if you need assistance let me know.
1/8/2011 3:28:10 AM •
Motorola...
Answered
on Jan 08, 2011
Hi I have a motorola cell phone V9x. I unlocked it
You
can
get the unlock code by contacting your current service provider
customer care department. If your phone is locked you can use any of
your friends phone to make this call. The
service
provider will then provide you the unlocking codes.
Remember
that the reason why the codes are provided only through customer service
provider is that, they will make a check on your name and identity proof
at
the time of your call. If the information is found to be correct and
matching with their data then you will be provided with the codes.
Everything is done for free of cost and you are not going to be charged
for this process.This
is
the universal solution and is useful for many customers who are
facing these kind of problems. Don't believe in any websites which
provides unlock codes. All are fake. Only your service provider can
provide these codes.
Another alternative is, you can take the
phone to any authorize phone service center to help unlock the phone,
because to unlock your phone, you will need some kind of software, USB
cable
etc to unlock the phone, so you can also go a nearby phone service
center to unlock the phone,
but calling your network service provider is the best because they have
the records of your phone and can easily help to unlock it. This are the
two reliable means you can unlock your phone.
Take care.
8/9/2010 2:48:01 PM •
Motorola...
Answered
on Aug 09, 2010
I have tried to turn off the call divert function
call divert is something more concerned with ur service operator than ur phone. some operators have some special sms's to be sent for cancelling call diverts. please verify with ur customer care.
2/16/2010 9:43:07 AM •
Motorola...
Answered
on Feb 16, 2010
V9x soaked in the rain - hoow expensive to fix?
remove all covers and battery, take out the sim card and then wrap it all in tissue paper and place in an airing copboard or very warm, dry room. Leave it for 24 hours, re-assemble and should be good to go, if not it is probably not woth fixing.
2/7/2010 5:24:29 PM •
Motorola...
Answered
on Feb 07, 2010
Sending music
usually, you have to go to the actual music file and select the send option, this will then give you sending options such as send via bluetooth or mms.
6/27/2009 11:42:28 AM •
Motorola...
Answered
on Jun 27, 2009
Sim Network Unlock Pin Motorola
How to enter my Unlock Code on Motorola ?
Model : All Motorola
1 - Switch ON your phone with a not allowed SIM Card,
2 - Phone show "Enter Special Code",
3 - You can now enter the Unlock Code we send to you.
WARNING : If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
https://www.unlockbase.com/faq/en/Q_47.html
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
Yesterday
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
2 days ago
