20 Most Recent
LG CF360 Cell Phone Questions & Answers
WHY DOES MY PHONE SAYS INSERT SIM
try taking SIM and battery out placing it back in an powering on.
If you try this and it still does not work you may need a new SIM card.
Take it to a local dealer they should have a new SIM they will put your
number on it and you will be back in business.
If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
good luck
Free site unlock code
When i searched through Google,I didn't find any free unlocking site for your mobile model.So you have to go for paid unlocking service.If you need cheapest unlock code visit
Superunlockcodes.com Here you can unlock your LG CF360 phone within a day.
I can hear people, but they can't hear me -
Check if the microphone is not muted. The mute button is at the top left of the keypad when a call is being received or made. If the mike is not muted, then try the following steps:I. Switch on phone with SIM Card.2. Select Menu.3. Select Settings.4. Select Call.5. Select Hearing Aid.6. Set Hearing Aid to OFF. And that should solve the problem. If this does not work then the microphone might be damaged and may need to be changed.
People can not hear me on my phone but I can hear
This is Jon from the Cell Phone Guy in Sioux Falls SD. I do repairs on cell phones all day everyday and see alot or similar problems. It sounds like there is a problem with your microphone. Have you ever had water damage? if so there is a 50/50 shot a may work again. We use an altrasonic cleaner whenever there is a water damaged phone for repair and its not always a guarantee but it seems to do the trick most of the time. If there has been no water damage to your phone to your knowledge it may be that there is just a loose connections? or that the microphone has gone out that is a bigger issue. on most phones the microphone is soldered onto the mother board of the phone making it very difficult to replace or repair. if you would like to discuss it more you can send me an email at
[email protected] to diagnose the problem further
Jon at The Cell Phone Guy in Sioux Falls SD
www.thecellphoneguyonline.com
Microphone problem LG CF360-Blue
Steps:I. Switch on phone with SIM Card.2. Select Menu.3. Select Settings.4. Select Call.5. Select Hearing Aid.6. Set Hearing Aid to OFF. And that's it Problem solved
Lg CF360 can recieve sms but cant send sms
for sending text messages :1.go to your message settings and check the message center number to see if it is correct2. call to your network operator customer care3. request the message center number...4.note it down5. go to message settings>message center number6. insert the number which is noted by you and save itthis solves your messaging problem ...Good luck
