20 Most Recent Sony Bravia KDL-32ML130 32 in. LCD TV Questions & Answers
it is hard to be sure what the issue is but are you sure it is not the cable or hdmi connection are you using an air antenna or actual cable or satellite signal this issue sounds like a non cable service issue meaning you have an air antenna hooked up is this true?
Sony Bravia... | Answered on Jan 24, 2018
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sony Bravia... | Answered on Apr 17, 2014
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Sony Bravia... | Answered on Dec 09, 2011
LCD Panel (screen) is defective and need to be replaced to solve this problem.
Click YouTube.com to watch similar problem in lcd tv that brought to my repair shop.
Thanks.
Sony Bravia... | Answered on May 30, 2011
According to the symptom problem is not so critical, the software needs upgrade. Today i am doing same with another model with same symptom, although updating of software is not big deal for us but i will suggest you to please contact any sony service center or expert nearby, because we do this in routine but lot of things involve like, for software update you need original USB (1GB,2GB but not higher) of Sony, and do some changes after updating in data etc, Which will make it difficult for you, So i will suggest you get it to the nearest service center and they will get nominal charges of it.
Please let me know if yo need further assistance on comment column.
Thanks for understanding.
Sony Bravia... | Answered on Nov 24, 2010
try to check the all the connection of your tv, specially the aerial connection.
Sony Bravia... | Answered on Oct 18, 2010
You have a weak electronic component called a capacitor. You have to let a tech replace it for you. This will cause your LCD to suddenly loose brightness
Sony Bravia... | Answered on Aug 24, 2010
try using different hdmi inputs if you ave any
Sony Bravia... | Answered on Aug 20, 2010
The little board on top attached to panel.
Sony Bravia... | Answered on Jul 05, 2010
Please check out the power supply and the inverter boards.
Please see my basic troubleshooting guide here:
https://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Sony Bravia... | Answered on Jun 17, 2010
Pl have replaced by the authorized service provider.
If it is economical to change the TV, do so!!
Sony Bravia... | Answered on Apr 16, 2010
Question post shows its Sony KDL-32ML130 lcd tv.
Let me know what part of screen has darker image or its all over darker picture.
Thanks.
Sony Bravia... | Answered on Mar 02, 2010
How dark is the picture? Is it always like this no matter what settings? There are a couple possibilities. It is very possible its a back lighting issue. How long have you owned the tv? How long have you had this problem? Once I have more information I can assist you further.
Thank you,
Lee
Assuming the tv is connected properly, no overloads, and well taken care of:
this is a video power management problem with in the tv, theres and ac/dc arching, it roots from the power supply module of the time-control board. The interface board plays a roll in this problem also as it controls convergence and down-stream video. have a technician take a look at it or if its under warranty take it back.
for more information contact us:
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
CWR-on_line Tech Rpt
Sony Bravia... | Answered on Oct 29, 2009
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Sony Bravia... | Answered on Oct 27, 2009
Sony Bravia KDL-32ML130 32 in. LCD TV Logo
35 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
intermitant audio static
  • Televison & Video
