20 Most Recent Samsung LN40A500 LCD TV Questions & Answers
reset the remote,press and hold the power button for 90 seconds without batteries in it, if issue not resolved, tv need for repair
Samsung LN40A500... | Answered on Dec 28, 2014
Faulty tuner on mainboard would be my guess. You can find main boards for your model at shopjimmy.com Search results for LN40A500
Samsung LN40A500... | Answered on Nov 26, 2014
Hi Jorge
Check on the remote if the buttons aren't stuck / sticking then check on the side panel of the television if the button there are not pressing against anything.
Lastly check to see your channel setup is fine and do a auto scan for the channels to ensure that it's not a memory issue
Samsung LN40A500... | Answered on Sep 28, 2014
A photo might help, my guess would be either the main board or the display panel itself especially if it looks like a swirling black cloud.
Samsung LN40A500... | Answered on Dec 12, 2012
Count the number of times of flashes at one time. These count indicates fault symptoms and related boards. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Samsung LN40A500... | Answered on Nov 29, 2012
The new board may be causing this--either defective or the set needs a reset of some type---get the board from Samsung or where?
Samsung LN40A500... | Answered on Jun 16, 2012
I've tried everything except replacing parts on a component level. I don't have a digital volt meter so cant measure what is working. Visually checked all the capacitors and it all looks good. Don't really want to replace the whole power supply cause everything is still good. What can I do, and if push comes to shove, where would i get a power supply from and what part number would it be.
Samsung LN40A500... | Answered on May 30, 2012
The tv have 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the tv LCD screen panel to have a backlight to produced a picture.That why u have audio only no video.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Samsung LN40A500... | Answered on Jul 07, 2011
Replace the power supply to start with as it sounds like a capacitor has blown. If power supply is o.k then Im afraid your projector may be faulty but I'd be fairly confident its a capacitor, They are 80% of the problems we see coming in for repair. You can examine the power supply and see if you can identify the faulty capacitor and cut it off the board and solder a new one on of the same rating. It will be fairly obvious if one has blown as it will be burned and split. Dont touch any capacitors without discharging them though or you could get a bit of a shock. Google how to discharge a capacitor and youll see directions. Hope this helps.
Samsung LN40A500... | Answered on Feb 25, 2011
I just fixed a friend's set that had the same symptoms.
Multimeter check: all the expensive parts are still good!
Physical check: Hmmm this pair of 10V 1000uF caps are bulging on their tops. ( they are located by the output connectors ).
I swapped out the two bad caps. and Bingo!
Jeffrey
Samsung LN40A500... | Answered on Aug 01, 2010
good day i think theres a parts that links to the main board is shorted. causing not to on your tv. you need a qualified technician to fix that problem,
Samsung LN40A500... | Answered on Jun 20, 2010
Adjust the aspect ratio on the tv and or the cabls/Sat box.
Samsung LN40A500... | Answered on Apr 16, 2010
It probably is the Keyboard on the side. I've had this quite a few times. Simply pull off the back and unplug the side keyboard. It should be the last board in a chain of wires coming from the main to the IR sensor then finally keyboard. Unplug the keyboard and then plug TV back in and see if it stops, if so that was your problem, if not it will likely be your main board then. The TV usually can operate without the key board you will just have to use the remote for everything, but the keyboard is generally pretty cheap like $15.
Samsung LN40A500... | Answered on Feb 18, 2010
need replaced power supply boaed
Manufacturer Samsung Part Number BN44-00199A Description IP BOARD;IP-211135,P
Samsung LN40A500... | Answered on Nov 30, 2009
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
Samsung LN... | Answered on Jan 16, 2018
Samsung LN40A500 LCD TV Logo
33 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
tv quit working
  • Televison & Video
