20 Most Recent Goodmans GTVL32W27HDF 32 in. LCD TV Questions & Answers
Type in details google search or other, should come up with manual
Goodmans... | Answered on Aug 10, 2014
The yellow wire is plugged in wrong in the back. Or the red/green/blue cable is plugged in wrong.
Goodmans... | Answered on Jul 29, 2014
Check the signal strength. If the signal strength is weak, this can happen to digital channels. For analogue channels, the fault due to weak signal will be a grainy picture.
Goodmans... | Answered on Jul 26, 2014
There should be a short circuited component/s at its main power regulator board. Check and replace it. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Goodmans... | Answered on Nov 02, 2013
check the sound setting on the sky box go to setting, then sound. audio out stereo
digital audio out optical (dolby D)
digital audio output hdmi (normal)
digital audio output delay (0ms)
this is how the settings should be digital out put hdmi only works with full HD 3D tvs.
Goodmans... | Answered on Oct 02, 2013
There is a problem with the power supply
Goodmans... | Answered on Mar 02, 2013
The LCD backlight is faulty. it may be due to bad capacitors or a faulty inverter controller. Bad capacitors can be easily replaced. A faulty inverter controller is a bit more tricky but it can also be replaced.
Goodmans... | Answered on Feb 10, 2013
Most likely you have a short on the front side of your power supply. You will either need to have it repaired or replaced!
Goodmans... | Answered on Oct 23, 2012
im having same problem, did u find a solution
Goodmans... | Answered on Oct 15, 2012
Backlight failing
Goodmans... | Answered on Sep 18, 2012
you have no back light , the invertor pcb may be faulty or worse still the screen may have failed.
This needs a service engineer to diagnose properly
Goodmans... | Answered on Aug 01, 2012
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Goodmans... | Answered on Jul 28, 2012
Check this site for more details. "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English.
It has more details the may help you to do this work yourself.
Goodmans... | Answered on Jun 18, 2012
Goodmans GTVL32W27HDF 32 in. LCD TV Logo
124 questions posted
Top Goodmans Televison & Video Experts
Ekse
Colin Stickland
Colin Stickland
martin hogg
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Goodmans Televison & Video
Most Popular Question
39 t get rid coloured horizontol
  • Televison & Video
