20 Most Recent
Panasonic VIERA TX-32LXD80 32 in. HD-Ready LCD TV Questions & Answers
I have a Panasonic Viera
If you are using a direct Cat5/6 cable connection between the unit and the modem, you should not have to enter any codes as this is a direct communication from one device to the other. If you were using Wi-Fi Wireless, ye; then you need codes to authenticate the connection.
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Bought in Dubai 3 years ago Pan.Viera LCD
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Stand on t.v
There are six screws at the back, at the bottom, three on each side. Undo them and the base pulls out. Beware, it's very heavy.
No problem - IF you do ALL 6 of them !
What board should I change
Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
