20 Most Recent Sanyo DP46848 LCD TV Questions & Answers
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
Sanyo DP46848... | Answered on Jun 29, 2018
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sanyo DP46848... | Answered on Jun 16, 2017
Not true that its def the power. Mine did the same thing. Green light, no sound or video. Replaced the power board with same results. Waiting on main board now.
Sanyo DP46848... | Answered on Feb 20, 2017
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Sanyo DP46848... | Answered on Nov 30, 2016
tvs have a very complex system inside, when a component goes bad many times they will fire up until they get hot and then quit working, it takes a professional to fix in most cases. you can search you tube for this model and see if anyone has posted a repair for your problem but if you don't know how things come apart or how to solder etc it is best to let a professional repair it or get a newer set
Sanyo DP46848... | Answered on Feb 03, 2016
The left side of my tv is going black. Why is it doing this?
Sanyo DP46848... | Answered on Nov 08, 2015
This can be a bad power board, or a fried tuner board. You need to provide more details to get any deeper on this issue.
Sanyo DP46848... | Answered on Jan 02, 2015
If you want to update it with the latest firmware, you have to enter the official website to Sanyo; or contact the authorized Sanyo service centre. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sanyo DP46848... | Answered on Oct 24, 2014
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Sanyo DP46848... | Answered on Jul 20, 2014
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Sanyo DP46848... | Answered on Apr 27, 2014
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Sanyo DP46848... | Answered on Apr 26, 2014
It could be your current problem, but it is not the problem causing the lines.
You can send the main board to us and we can test it and see how it behaves, possibly fix it, but we likely won't be able to take care of those lines.
Sanyo DP46848... | Answered on Apr 18, 2014
See if you can change the input. and see if it is any better. If not there may be something loose internally. I don't recommend attempting to repair yourself, but having a tech do it can be pricey. Try and leave the TV off for 24 hours and trying again, if it persists you may need to replace the TV. Good luck
Sanyo DP46848... | Answered on Apr 10, 2014
Sanyo DP46848 LCD TV Logo
132 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
sanyo tv model dp46848 one half sreen
  • Televison & Video
