20 Most Recent Sharp LC-32SB23U 32 in. LCD TV Questions & Answers
2answers
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/14/2020 11:52:02 AM • Sharp LC-32SB23U... • Answered on Jul 14, 2020
Problem With the Sharp TV LC-32SB23U 32in LCD TV Serial No# 810825838
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/25/2017 12:22:20 PM • Sharp LC-32SB23U... • Answered on May 25, 2017
After about two minutes of the unit being on, it automatically shuts off. The power led shows orange when the unit is on and blinks green when its off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ If blinks continue without any pause, the main board is faulty
4/29/2016 8:47:18 PM • Sharp LC-32SB23U... • Answered on Apr 29, 2016
My 70 inch Sharp TV flashes but it wont turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
1/21/2016 1:06:47 AM • Sharp LC-32SB23U... • Answered on Jan 21, 2016
Volume goes off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
12/1/2015 6:22:32 AM • Sharp LC-32SB23U... • Answered on Dec 01, 2015
Is the audio amp on the main board of a sharp lcd tv
A manual for a measure of the voltage line thats goes to the audioboard and there can be used a fuseresistor a resistor to protect the audioboard if ....... SHARP LC 32M44L LC 32SBB21U LC 32SB23U LC 32SB220U SUPP Service Manual... Suc6
11/24/2015 7:06:30 PM • Sharp LC-32SB23U... • Answered on Nov 24, 2015
Is the audio controlled by the power board or the main board or both
Power board supplies voltage to audio section circuit. The audio output section circuit might be in a separate board; or it will be a part of the main board. It will depend on the circuit design of the company. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
10/25/2015 3:47:59 PM • Sharp LC-32SB23U... • Answered on Oct 25, 2015
2answers
Where can I download a updated software driver for
If you refering to firmware upgrade- there is non avalable for this model.
5/4/2015 8:26:40 AM • Sharp LC-32SB23U... • Answered on May 04, 2015
How do i program my dish remote to my sharp tv
call dish
12/8/2014 9:13:43 PM • Sharp LC-32SB23U... • Answered on Dec 08, 2014
Is my tv wifi capable?
Refer its user manual for details. The specification page will have all. Gopakumar Gopalan Google
8/10/2014 11:39:15 AM • Sharp LC-32SB23U... • Answered on Aug 10, 2014
Flashing power and OPC lights on tv and does not come on. What is OPC and how can this be fixed?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
8/3/2014 12:18:16 PM • Sharp LC-32SB23U... • Answered on Aug 03, 2014
Why is the color in the picture isn't clear it's fuzzy
There are so many reasons for this. It will be best to contact the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
6/12/2014 5:23:35 AM • Sharp LC-32SB23U... • Answered on Jun 12, 2014
Color
Contact cable provider.
6/12/2014 3:10:13 AM • Sharp LC-32SB23U... • Answered on Jun 12, 2014
Picture goes blck, power button flashing green
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. http://electronicshelponline.blogspot.com/
1/24/2014 3:32:21 AM • Sharp LC-32SB23U... • Answered on Jan 24, 2014
0answers
Not on
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
11/26/2013 7:33:28 AM • Sharp LC-32SB23U... • Answered on Nov 26, 2013
Sharp 32 32sb3u
The resolution that the Xbox is pushing out is most likely too much for the TV, and it switches off because it can't physically display the signal. Try hooking the xbox to another TV (if you have one) and setting the resolution to something in the neighborhood of 420p so that you can see the screen. After you do this, take it back to your TV and switch it slowly up in resolution until it blinks out. When it blinks out, you know that the resolution is too much.Change it back to the next lowest resolution and play away.
6/26/2013 5:45:22 PM • Sharp LC-32SB23U... • Answered on Jun 26, 2013
Sharp LC-32SB23U 32 in. LCD TV Logo
76 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
flashing power opc lights tv not come
  • Televison & Video
