20 Most Recent
Nintendo DSi Matte Blue Console Questions & Answers
Can't connect error code 051100-1
Error Code: 051100The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance,
click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
- Errors ending in 0 = connection file 1
- Errors ending in 1 = connection file 2
- Errors ending in 2 = connection file 3
- Errors ending in 3 = Nintendo Wi-Fi USB Connector
Nintendo DSi bottom screen flashes then dies
You almost certainly have one or more blown capacitors on the board (probably just one). You will need to open it up, find the blown capacitor (convex top, instead of flat), and replace it. If you are unsure about doing soldering work on a board, get a friend who does this kind of thing. It's not expensive.
I Have A Error Code 051099-1. But I Don't Know How To Fix It. So Can Somebody HELP ME PLEASEEEEEEEEEEEEEEEEE. THANK YOU I REALLY WANT TO USE MY INTERNET AND ONLINE MULTIPLAYER TO.
Hey there!
My name is Austin Burk.
Error codes around 52000 generally mean that your console was unable to connect to the internet at all, or at least, unable to contact the Nintendo servers that handle statistics and such.
The Nintendo Wifi connection was shut down on May 20th, 2014.
So games that use that won't have any more online functionality.
Flipnote Hatena shut down May of 2013, but I recreated it. It still works fine, feel free to try it!
www.sudomemo.net
You should start by checking if the DSi browser works. Try a new internet connection, perhaps. Maybe your wifi has some sort of 'agreement' screen you need to agree at first. Nintendo DSis sometimes don't like those, however..
You can help in the future by providing more details on the issue you're having, like what game you're trying to play, or whatever other info you can provide.
What is going on with my LR button?
My condolences for your loss. :P
The Nintendo DSi's L and R buttons are notorious for breaking. While the best and quickest way to fix them is to replace the entire back assembly (or just the ribbon cable, but that would require a lot of precision if you want to get it all aligned perfectly), a trick we all use is to cover the entire button with your mouth and kinda blow into it. It's probably bad for the system or something, but most of us don't care as long as it works. As a hardcore DSi user, there's my advice.
By the way, if you liked Flipnote Hatena, I've recreated it so that you can use it directly on the Nintendo DSi. I call it Sudomemo. Maybe you'll enjoy it?
sudomemo net
Wishing you a wonderful day and some working L and R buttons,
Austin Burk
"Sudofox"
I forgot my master key
Call Nintendo at 1-800-255-3700. They can give you a master key to reset your parental controls. Hope this helps.
No sound at all
Do you have sound at all? If you have none sound try plugging in headphones and see if you have sound there. If you do and you can increase and decrease the volume then it is a problem with the internal speakers of the headphone jack. (May need to clean it by cutting the end off a q-tip and jamming it in and out.
Can not remember pin number
Hi, Reset your game player with rest button (a tiny hole at top) with the help of any stick and press the reset button. This will change it to factory settings you player.Thanks
