20 Most Recent Veo Observer Network Camera Questions & Answers
0answers
Veo Observer
Be the first to answer 7/25/2017 11:39:04 AM • Veo Observer... • Posted on Jul 25, 2017Be the first to answer
0answers
Veo Observer
Be the first to answer 7/23/2017 12:12:03 PM • Veo Observer... • Posted on Jul 23, 2017Be the first to answer
0answers
0answers
0answers
2answers
Veo Observer network camera
Make sure that you are using Internet Explorer 5.0 or higher. If you are experiencing problems, try upgrading to the latest version of Microsoft's Internet Explorer from the Microsoft webpage at: http://www.microsoft.com/windows/ie Method A: 1) Go to C:\Program Files\Veo Observer Studio and delete the files: xrlknc.dll and xrlkncd.dll. 2) After the files have been deleted, try using the Veo Observer Studio again. --or-- Method B: 1) Uninstall the Veo Observer Studio from your computer. 2) Download the latest version of the Veo Observer Studio from our webpage at: http://www.veo.com/Observer/firmware.asp if it still has the same promblem refer to your display or the grafix recommendations
3/5/2014 2:44:00 PM • Veo Observer... • Answered on Mar 05, 2014
2answers
Problems with cam veo sn/601VB35X observer
It can bre the password expires every 30 days or 3 mnth or sumthin....Check the firewall ( TURN IT OFF )
3/3/2014 3:14:35 PM • Veo Observer... • Answered on Mar 03, 2014
4answers
Veo observer firmware
3/3/2014 3:13:55 PM • Veo Observer... • Answered on Mar 03, 2014
2answers
VeoNetwork Web cam
You can view your Veo Observer web cam at home by either of two methods. The first is to use the Observer Studio software that came with the camera. When you configured the camera, you selected a local (private) IP address for each Veo Observer, and set the address specific to each camera. You then put the same IP address into your Observer Studio Software.
Depending on the brand of router you use on your home network, your Veo Observer camera probably has a local (private) IP address in the format 192.168.0.xxx or 192.168.1.xxx where "xxx" is the actual address assigned to your Veo Observer (by you) and configured to display on the LCD window on the side of the Veo Observer.
You may need to log into your router to see which of the two local (private) IP address formats is used. Your router's user manual will show you how.
To view your Veo Observer, just type the exact local (private) IP address in your IE browser. for example, if you assigned address 100 to your cam, you would enter http://192.168.0.100 or 192.168.1.100 into your browser. Veo Observer will display the Language selection screen. Choose the language, then you log in and view your camera.
To view your camera from outside your home using another computer, you use the same method, but you have to substitute your WAN (public) IP address.
You can log into your router and select its STATUS tab to view your WAN (public) IP address. See you router's set up guide if you do not know how to do this.
An easier way to determine your WAN (public) IP address is to visit Gibson Research Shields Up! web page:
https://www.grc.com/x/ne.dll?bh0bkyd2
and scroll down to the last paragraph where you will find your WAN (public) IP address.
For example, if this address is 123.456.789.100, then you would enter http://123.456.789.100 on your IE browser. You should see the Language select screen, choose your language, then log in and you are now viewing your Veo Observer from outside your home.
Note: when you view your Veo Observer at home, you probably have a fast frame rate and smooth video motion. When you view your Veo Observer from outside the home, the frame rate is certain to be less, and your moving image quality will be choppy. This is normal, as viewing from outside the home is less efficient and the image suffers. There is nothing you can do to boost the frame rate.
2/24/2014 3:03:59 PM • Veo Observer... • Answered on Feb 24, 2014
2answers
Window Vista Problem
Using the OPTIONS menu of IE, select SECURITY. Scroll through and find the check boxes for downloading unsigned and expired ActiveX code. Remember what the current setting is, then uncheck the setting to temporarily allow expired or unsigned ActiveX programs to download.
Try your Veo Observer again, download the ActiveX and when you are sure it is working, go back to IE OPTIONS and change your ActiveX options back to their previous settings, which was to NOT allow expired or unsigned ActiveX code to download..
2/24/2014 3:03:50 PM • Veo Observer... • Answered on Feb 24, 2014
5answers
Veo network camera
The software is on the camera, all you have to do is connect it to your network and let it get an IP address, after it shows an address on the side window, use internet explorer to go to that address ( 192.168.1.XXX) or whatever the mask is for your network, make sure internet explorer is set to allow activex controls downloading, the browser will download the control and ask for password and user name, the default is "password" and "admin" good luck
2/24/2014 3:03:30 PM • Veo Observer... • Answered on Feb 24, 2014
3answers
I want to know Default User Name and Password
For mine, the default is
username: admin
password: password
2/23/2014 4:46:34 PM • Veo Observer... • Answered on Feb 23, 2014
2answers
Not able to run, get error Veonetcam Active X
That happens to me also. This is because the valid date for the security certificate is too old. Check the details for the error message & you should see a link to let you view the certificate. Look for the valid date for the certificate. In our case it's 8/20/2002-8/21/2003. Change your system's date (just the year is all that's necessary) so that it falls in that range & try again. Once the ActiveX control is downloaded you can change the system date back to the current date.
2/20/2014 3:46:55 PM • Veo Observer... • Answered on Feb 20, 2014
3answers
Veo web cam. Who can repair?
Hi.
I suggest contacting Advance Camera Repair. They repair any kind of optical equipment, I guess that they can repair a Veo Observer.
Here repair form: Repair
Here Contact: Contact Us
If they can carry the repair, then you will be asked to ship them the cam.
Let me know how it goes, if this helps please do not forget to accept the solution afterward.
All the best.
Ginko.
2/18/2014 2:55:33 PM • Veo Observer... • Answered on Feb 18, 2014
Is user name different than user ID, password etc
they same
10/30/2013 3:35:05 AM • Veo Observer... • Answered on Oct 30, 2013
Como puedo resetear mi camara o cual es la
1st You download Webcam Driver.Como puedo resetear mi camara o cual es laAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
2/28/2013 5:18:59 AM • Veo Observer... • Answered on Feb 28, 2013
How to download the usb webcam?
1st You download Webcam Driver.How to download the usb webcam?After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
2/28/2013 5:18:07 AM • Veo Observer... • Answered on Feb 28, 2013
Need instructions to set up siemens 4200 modem for veo observer
1st You download Webcam Driver.Need instructions to set up siemens 4200 modem for veo observerAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
2/28/2013 5:17:21 AM • Veo Observer... • Answered on Feb 28, 2013
Veo Observer Network Camera Logo
81 questions posted
Top Veo Computers & Internet Experts
ExpressFiX
ExpressFiX
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Observer Veo
  • Observer Veo
Most Popular Question
veo web cam repair
  • Computers & Internet
