20 Most Recent Amazon Kindle 2 Questions & Answers
Go to Menu button
Move to setting
Go on 2nd page
Here you check serial number
For any other query regarding Amazon kindle please contact Kindle support number
Amazon Kindle 2 | Answered on Sep 18, 2019
Welcome to FixYa.
1. Make sure that your Kindle is charged properly.
2. Unplug it from the power source if it is plugged in.
3. Slide and hold the Power switch for 15 secs. then release.
4. Note that the Kindle screen will go blank for about 30 secs. while it restarts.
Thank you for using Fixya. Have a great day.
Amazon Kindle 2 | Answered on Aug 28, 2018
You just need to consult with the amazon kindle Support. Ask them the question as many as you can Kindle Technical Support Registration 877 690 9305
Amazon Kindle 2 | Answered on Mar 20, 2018
Do you mean they are not on your carousel? Your kindle may be deleting them to make room for more books since they have a limited amount of space. Any of your books are still on your amazon account and can be downloaded again at anytime at no additional charge.
It is simple and easy you need to register the Kindle on Amazon. You can call the Amazon Kindle Support if you are facing any issues. Kindle Technical Support Registration 877 690 9305
Amazon Kindle 2 | Answered on Mar 17, 2018
Let Kindle know you lost it. Then prepare to move on to a new Kindle. I lost my Kindle 3G a couple of years ago. Never been heard from since.
Press and hold the power button for fifteen seconds or so, ignoring any "Shut down?" prompts, until it turns off. Release the button, then press and hold it for a second or two until it starts to reboot.
Amazon Kindle 2 | Answered on Mar 02, 2018
there's a little pinhole at the bottom. insert a paper clip to do a hard reset. Or remove the battery and re-insert it to the same effect.
If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? It may show something on the sreen, even if it is not turned on (e-ink screen does not need a powersupply to show an image). Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Amazon Kindle 2 | Answered on Feb 24, 2018
If you are not under warranty, replacement will be needed, anyway you can still contact them. here: Amazon com kindle 2 replacement screen. Wish you best of luck.
Tim
Amazon Kindle 2 | Answered on Jan 05, 2018
This may be handled by support better. It's free and doesn't take much time to get answers.
You can reach Kindle Customer Support via phone or chat by clicking one of the links below:
To contact us via phone:
http://www.amazon.com/clicktocall
To contact us via chat:
http://www.amazon.com/clicktochat
Amazon Kindle 2 | Answered on Sep 25, 2017
It all depends on the generation of Kindle you have. On mine I swip down from the top of the screen an the lighting an settings come up. Maybe this will help. Mine is 5 generation. On my earlier one it was different.
Amazon Kindle 2 | Answered on Jul 22, 2017
I'm afraid this usually means your screen is cracked. You can contact amazon customer support and they may replace it or you will have to but a new kindle
Amazon Kindle 2 | Answered on Mar 20, 2017
Try a different charger. If that fails too, you have a logic board issue. Amazon2_bing.gif should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Amazon Kindle 2 | Answered on Sep 27, 2016
check your wifi connection may have to resign on or problem with the site your trying to access
Amazon Kindle 2 | Answered on Jul 31, 2016
Hard and Soft Reset
  1. Make sure the Kindle is turned ON. ...
  2. Press the Power button for at least 20 seconds. ...
  3. Wait for it to reboot - wait a minute or two. ...
  4. Your kindle should be back to a responsive state.
  5. You will have to go through the setup again and then synchronize to put your e-books and other data back on the device.
Amazon Kindle 2 | Answered on Jul 20, 2016
Larry, Check the attached links,instruction and guides on how to ID your Kindle. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
Identify your Kindle Model
User Guides for Kindle 2nd Generation
Model number for kindle 2nd generation Google Search
Amazon Kindle 2 | Answered on Jul 06, 2016
Amazon Kindle 2 Logo
176 questions posted
Popular Products
Top Amazon Tablets & eReaders Experts
Poul Brinchs Larsen
Will Mishler
Will Mishler
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Kindle Amazon
  • Kindle Amazon
Most Popular Question
after update fully charging unable
  • Tablets & eReaders
