20 Most Recent
Gateway C-141x Tablet PC Questions & Answers
About a month ago my screen on my laptop would
Sounds like one of two things. Either your connection wire from the screen to the hard drive is lose most of the time you can go on the product sites enter the info on the underside of the computer enter that info on the products site and get your info from the help self section or the repair diagram. Number 2 is your screen has a bad wire and it needs to be replace you can find them new on ebay and most of the time it is easy to fix yourself.
I hope some of this info helps you.
My Gateway laptop model TB120 hinge is broken. any
This may help and may not. It seems there are lots of people having the same problem you are. The best way to get a replacement seems to buy a cheap junked out Gateway and use the hinge from it. However I would be very careful doing this because the one you buy may not have a good hinge. As many people there are with these issues I would contact Gateway to see if they had a replacement part and would ask to file an official complaint. In addition here is a number to a laptop repair company, they will help you find the most cost effective way to fix your laptop. They are good I have used them for parts before. 1 (800) 999-4409
I dont know if my
if you read the manual it'll be in there. if you don't have a manual, go to the gateway website and download one.
http://www.gateway.com/
My computer says no operating system
Check your BIOS to see if it's trying to boot to the floppy drive, or CD instead of the hard drive.
Try to boot to CD and see if it runs.
If you can get to CD, reinstall Windows and choose Repair, which will only copy the operating system files, and leave your data files intact.
If all of that doesn't work you may have had a hardware problem with the controller, RAM problem, power surge, or file corruption from any of those, or from a virus. In the end, the last extreme is to do a reformat and reinstall with fresh Windows and start adding your programs back on, one at a time.
Remember to keep your essential data backed up... at least once a quarter if you can! 8^)
:o)
Cannot connct to wi fi
A guide in .PDF format has been included on your hard drive that
provides instructions for installing and configuring both wired and
wireless Ethernet networking on your notebook. To access this guide on
your hard drive, from the
Start menu, point to
All Programs,
Gateway Documentation, and then click
Gateway Networking User's Guide.
The following are some of the topics included:
- Learning the Basics
- Creating a Wired Ethernet Network
- Configuring Windows for a Wired Network
- Configuring Windows for a Wireless Network
- Creating a Wireless Access Point Network
- Creating a Peer-to-Peer Wireless Network
- Turning Your Wireless Emitter On or Off
- Sharing Your Resources
- Troubleshooting Your Ethernet Network
A copy of this guide is also included on your Application and Drivers CD.
