20 Most Recent
Lenovo 3000 G530 Notebook Questions & Answers
How do I play my on dvd's
Hi, the only way to find out is to put a dvd in if you have the software on the unit it should automatically start up for you. It won't do your pc any harm if you don't have the software just eject the dvd out. You can download free VLC media player from the internet and this package will play your dvd .
My laptop is automatic shutdon imidiatly
Have you check your fans if its working?
1. Check the fans if not working you must replace it or put some drop of machine oil.
2. Remove any dust blocking the airways from fans to heat sink.
3. Lastly check your software install there's might drivers conflict or infected by virus. This software issue might cause for the system to automatically shutdown
Do Lenovo laptops kill non-Lenovo hard drives?
Yes, I had the same ...
To put things right I downloaded Linux Ubuntu (
http://www.ubuntu.com/download), burnt it to dvd and used the non-working hard drive as the only master drive, and installed Ubuntu as the operating system. Then I erased Ubuntu by installing Windows XP.
As you already have Windows working on your computer, why not create a 'virtualbox' and install the tech preview inside your current operating system? Search for for Oracle virtual box for Windows hosts (http://www.oracle.com/technetwork/server-storage/virtualbox/downloads/index.html), download it and also download the guest box additions.
That just means if you have say, Windows 7 as your operating system, you create a virtualbox and install another operating system inside that virtualbox. You can run both operating systems at the same time.
If you don't fancy the idea of a virtualbox, you can use the inbuilt Windows disk partitioner to create another drive on your hard drive and install the tech preview there. Your computer will be 'dual boot' ... at start up you choose which operating system to use.
You can do the same using Linux - but be aware that Linux must go on as the SECOND operating system.
Your first port of call is to format those hard drives and put things right.
About lenovo G450 audio driver
find your driver from these site:
1) forum.lenovo.com/.../Lenovo...G450-Audio-Driver/.../14
2) consumersupport.lenovo.com/.../DriversDownloads/drivers_list.aspx?...
3) consumersupport.lenovo.com/.../DriversDownloads/drivers_show_1373.html
How do I restore my computer back to a month when it was working right?
If you have not made a let it load and select system restore point on your computer it will be difficult. You must make a system repair disk or put in any Windows cd. Let it load and go farenough to the screen repair or restore computer. You also can do it by turning on your pc and hit F8 Immediately tapping till you hear a beep, then go to system restore. If you don not see last month, you can select see more restore points. Then select the date you want .( should be like a critical update point)
