20 Most Recent HP Pavilion DV7-1232nr Notebook Questions & Answers
2answers
When you turn on the
Does the BSOD show any code?
11/16/2017 12:39:41 PM • HP Pavilion... • Answered on Nov 16, 2017
Upon turning on computer, screen remains black, power button, volume, speaker, etc. lights up, fan on, but NUMLock/Caplock LED's blink continuously (no pattern). Was able to get screen to appear
that error means BTW, POWER IS TOO LOW. !one guy said what is power?, I said well, "it runs on DC power, from the power pack and bank of regulators in side, and if power is bad, all is hopeless until fixed. " We test that using magic tool called a voltmeter,guessing zero here. we do tests.if that is not clear, have it serviced in a shop.we first clean the PC and get out all that lint that causes overheating.http://www.pcdied.com/overheated.htmlDV7-1232nr " Was able to get screen to appear"? what screen? , keep in mind , we are blind herein a silly text box. post photos of screens?be like the first ever.?We do sequenctial tests to fix PCbooting is serial process, so that is the path to proper diagnosis on all PC.lets see , that now. 6 year old PC, best I can tell1: main battery out! if PC runs now, the battery is bad. end story. buy one or leave it out for ever.2: line pack , make sure 19vdc makes it to the MOBO, as for sure , no power there , NO JOY, ever. ok? use a volt meter, to test power or buy a new AC/DC PACK if guessing is the order of the day.3: BIOS screens are first, forget windows, or what ever OS you run, (unstated by you ,sadly)4: The BIOS screens are F10 or ESC, older is f10the PC prompted you for 6 long years, hit F10? to enter setup, so that be it.Power on and quickly n hammer the F10 key, see BIOS?5: if the bios screens are dead, no text ever.our gold is BIOS. first. then the CCFL H3LL.PC older than 2010 were NON LED screens and wereCCFL tubes (that sux) the fail, the all fail fast.in fact left on in 2years the die. longer if LT unused mostly.your PC has CCLF, they can go dim,blink,go yellowor die or even go INTERMITTANT.one day ok, next not this is the magic world of CCFL, all do that , now or soon ,for sure.see the flash light trick yet. as seen herehttp://www.pcdied.com/monitors.html#flashlighttestLets say the LCD is truely dead not just back lamp dead. what thenI told you its serial process , and is.next is what, well the PC told you power was bad.in fact so bad the LCD data part is dead.the PC can not compute at all.due to low power.we then stip the PC down to its basic parts.from easy to harder in every case.labor, hard. dig. LT sux to work on, a fact,i pull the CD drive (testing boots each time)I pull the HDD drive.pull all memory but one testing each 1 by 1 for hope. deal.my mobo in my laptop has 6 or 7 modules. (i dont pull CPU)keep in mind any thing there seen can short. right?you do know shorting will overload your regulators. a fact of lifeso pull them all, wifi card,modem card, express card, blu-tooth module ,well pull all that can be pulled. after all again, learn that all things inside can short out. beyone here, is mostly main board doom.(mobo)some 2008 PC had solder ball failure,seems im not sure last your your was made, hoping not 2008., PC from H3ll MADE THEN.i can not for he life of me unstand the afraid comment..does that mean the PC runs ok after fiddling ityou never said that. only the fiddling parts.
10/11/2017 12:26:33 AM • HP Pavilion... • Answered on Oct 11, 2017
Where is the mute button on the pavilion dv7
There are several models of Pavilion Dv7 so I am not sure yours is similar to what I mention, but there are Pavilion Dv7 with a line of keys of top of the keyboard, with, on the same line, the computer power button on left, then the mute button, then a volume scroll zone.
7/27/2014 7:36:10 PM • HP Pavilion... • Answered on Jul 27, 2014
0answers
Why wont boot
Be the first to answer 5/3/2014 11:35:28 PM • HP Pavilion... • Posted on May 03, 2014Be the first to answer
Sound driver ze2050ea
try using intel software set up
7/7/2013 6:01:48 PM • HP Pavilion... • Answered on Jul 07, 2013
2answers
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • 2/26/2013 2:03:50 AM • HP Pavilion... • Answered on Feb 26, 2013
    I have a HP Pavilion dv7-1232nr Laptop. As soon as
    bad hard drive or memory card is loose more likely bad hard drive...have it tested...
    7/27/2012 5:07:07 AM • HP Pavilion... • Answered on Jul 27, 2012
    2answers
    How to factory reset hp
    Shutdown the computer, turn it back on then press and hold the F11 key while restarting to launch the HP Recovery Manager from the recovery partition. Then choose system recovery options.
    11/15/2011 10:12:23 PM • HP Pavilion... • Answered on Nov 15, 2011
    Replace power supply cable
    The part number for the replacement AC Adapter is HP Part # 609940-001. Here is a link to HP's website where the item is located, and you could buy a replacement directly from them.Thanks, and have a great day!If my solution helped you, please don't forget to leave positive feedback!
    10/13/2011 12:29:40 AM • HP Pavilion... • Answered on Oct 13, 2011
    I have installed a 2nd
    With XP and 2000, though, use Windows' Disk Management utility. Click Start > Control Panel > Administrative Tools > Computer Management, and choose Disk Management from the tree at left. Your new drive should appear, with a black bar indicating it isn't partitioned. Right-click the bar, and choose New Partition to launch the New Partition wizard. Installed drives and their partition schemes appear in the Disk Management window's lower-right corner.
    Click Next, and check that Primary Partition is selected; click Next again, to the Specify Partition Size screen (don't change the partition size in the "Partition size in MB" field); and click Next to advance to another screen, on which "Assign the following drive letter" should be selected. Click Next yet again (to the Format Partition screen), and ensure that "Format this partition with the following settings" is selected and that the "File system" drop-down reads "NTFS." Click Next a final time, hit Finish, and formatting begins.
    Formatting could take an hour or more, depending on drive capacity. But don't be surprised if your formatted drive has less capacity than the package claims. A 320GB drive, for instance, formats to about 300GB. Drive manufacturers advertise preformatted size, but a portion of the drive is inaccessible.
    Hope this information will help.
    Your response is very much appreciated...Thank you for using Fixya...
    9/24/2011 10:45:47 PM • HP Pavilion... • Answered on Sep 24, 2011
    I have windows updates problems
    Contact Microsoft by telephone. They offer FREE assistance for problems with Windows Update.
    5/21/2011 11:48:35 PM • HP Pavilion... • Answered on May 21, 2011
    I recently did a clean
    you can download all hp drivers for your notebook at www.hp.com this should fix your problem.
    1/29/2011 4:13:20 PM • HP Pavilion... • Answered on Jan 29, 2011
    Can I add a second internal HD to this notebook? I
    Yes it can, but maybe you might need to buy a caddy if required, or a head adapter if required to connect to your extra harddrive port.
    1/28/2011 3:36:10 PM • HP Pavilion... • Answered on Jan 28, 2011
    My HP pavillion dv7 keeps
    Be sure that the laptop is plugged in to the power supply before you start! Are you restoring from an image in the machine or a CD or DVD disk?
    Either way this takes quite a while and most manufactures warn you that the machine will reboot a few times (I have seen some take 5 reboots) to complete the task, so be patient.
    The last part of your question concerns me. If you power cycled the computer (turned it off then on) half way through the process it could be hard crashed. If you have the CD or DVD dish this would not be a big problem but if you are restoring from an image this could be bad. Let us know.
    Ron
    1/6/2011 4:53:58 AM • HP Pavilion... • Answered on Jan 06, 2011
    Monitor does not light up. Computer has power.
    Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. Remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
    12/27/2010 5:13:09 PM • HP Pavilion... • Answered on Dec 27, 2010
    If you put memory in
    If the memory block is not identical to the other installed memory block, it will not work. They must be identical.
    10/30/2010 10:32:06 AM • HP Pavilion... • Answered on Oct 30, 2010
    How do i replace the keyboard?
    hi
    give me the S/N of the computer (located on back) and i will get this information "how to replace the keyboard" for your HP laptop
    10/15/2010 12:54:04 AM • HP Pavilion... • Answered on Oct 15, 2010
    HP Pavilion DV7-1232nr Notebook Logo
    45 questions posted
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    Pavilion HP
    • Pavilion HP
    Most Popular Question
    hp pavilion dv7 1232nr laptop as soon
    • Computers & Internet
