20 Most Recent HP Pavilion dv7-1245dx Notebook Questions & Answers
3answers
Pavilion dv7 starts up then shuts down
This sounds like you have a bad DC jack on your motherboard. This is one of the most common problems with laptops and can be caused by jarring the DC plug in or hitting it into something or simply from normal use. As a result the pins on the DC jack become loose and consequently do not provide a charge to the laptop and battery. Wiggling the plug can make the loose pins contact sometimes which would explain why it "sometimes" works when you unplug it and plug it back in. Of course if this is the case then your battery is mostly out of power and that is why it powers off after a couple seconds. This repair costs between $150-300 from a professional repair shop and I would not recommend trying it yourself unless you've had experience soldering DC jacks
Another issue could be the CPU fan/heat skin if this is failing or the CPU is overheating the laptop will power off.
Please comment if you need further assistance
10/6/2020 12:46:36 PM • HP Pavilion... • Answered on Oct 06, 2020
Battery not charging
does the PC run good , battery out, and only on AC, it must. does it?
  1. bad battery
  2. bad power pack 19vdc 65w
  3. or bad charger chip in the PC.
did you give it 24 hours to charge.
2/16/2018 9:23:09 PM • HP Pavilion... • Answered on Feb 16, 2018
CPU Failure, push power button and the cap lock and num lock keys flash one time, and repeats
randomly run your fingers on your keyboard to loosen any stuck keys than restart again.
2/6/2018 12:23:30 AM • HP Pavilion... • Answered on Feb 06, 2018
Hp pavilion dv7 1245dx missing operating system
go to setup and change priority to HDD.
2/6/2018 12:21:38 AM • HP Pavilion... • Answered on Feb 06, 2018
HP Pavillion dv-7-1448 dx has no display
Try removing the battery and switching on the laptop with charger only.
2/6/2018 12:19:55 AM • HP Pavilion... • Answered on Feb 06, 2018
2answers
Keyboard stops workings
There is a reset option that is supposed to help if the KB doesn't work.. yours is random or sporadic but this might help: http://hp.dezide.com/ts/start.jsp?guide=NotebookKeyboardandTouchPadorClickPad.net&as=true&SFS=sdoc§ion=ccweb&language=english&lc=en&cc=us&action=step&response=0&step=C39975.C39953&session=89f43caa-ba00-4809-80e8-eed31a
2/6/2018 12:13:37 AM • HP Pavilion... • Answered on Feb 06, 2018
Display issues
no photo posted, of bad screen, why? why make help blind? the display LCD is bad. or is the 2008 , solderballs Nvidia chip failure. if the screen fails in BIOS (press f10 or ESC to enter setup an fails under boot CD linux or any kind the screen is bad test with big battery out, always. run on AC power only to test. do the funny LINES change if you gently twist screen case? i see reviews on this LT back to 2009 the vista review page on its support pages is stamped 2008 oops ! the BIOS screens are here. hit ESC then F10 dv7-1245dx this is called hp setup, its BIOS. if these screens look bad, bingo for bad screen LCD or the GPU. http://h10032.www1.hp.com/ctg/Manual/c01662442
1/1/2018 1:08:06 PM • HP Pavilion... • Answered on Jan 01, 2018
2answers
The card slot reader is not working/ doesn't
go to control panel -> system and security -> system -> device manager. that has a list of all the hardware on the computer, look for any items that have X ! or ? next to them. Could be that you don't have a driver loaded for that device.
12/23/2017 2:04:09 PM • HP Pavilion... • Answered on Dec 23, 2017
2answers
Are you Install voice control any software on your computer. cheek your control plan apps list.Are its automatically install uninstall them.
11/25/2017 3:27:43 PM • HP Pavilion... • Answered on Nov 25, 2017
2answers
Hard Disc Not Exist
You need to get into the BIOS screen and set the boot order so that the CD drive boots first. Then it will boot to the cd and tell you the same thing. That the hard disk has failed and cannot be found.
11/22/2017 3:09:51 PM • HP Pavilion... • Answered on Nov 22, 2017
Why would my HP Deskjet Ink Advantage 3525 cause my sony vaio SVT131A11L to crash?
From the description of the problem, this seems to be a driver issue. What Operating system are you using?
4/13/2017 12:50:49 PM • HP Pavilion... • Answered on Apr 13, 2017
Making loud noise like a
Most likely it is a fan problem. The fan could either be failing or caked up with dust. Most likely the laptop would have to be disassembled to get to the fan and repair/replace the fan.
thank you,
Lee
1/5/2015 3:43:58 PM • HP Pavilion... • Answered on Jan 05, 2015
Is there a keyboard that lights up that is compatible with my laptop?
Hi there! asking for keyboard lights! some of the solutions for ur problem are: 1. use external laptop keyboard with lights that are available in nearby PC store or electronics store else u may try it on online stores that may even offer deals. 2.Use USB light that illuminates light on keyboards that are more cheaper than keyboard replacement 3.If you are a DIY enthusiast and have hobby, and known knowledge of electronics try making LED illuminare from Ur laptop usb dongle out it may hav 4 pins say positive, negative, data positive and data negative and it supply around 5V supply with 1 amp current. try it may cost more cheaper than two solutions as i said above. 4. use low power bed lamp that focus on ur laptop keys. thats all bro! Have a nice day! bye! any question : [email protected]
11/27/2014 1:36:19 PM • HP Pavilion... • Answered on Nov 27, 2014
How to remove power on password HP Pavilion dv7-1245dx
another method I have used that works is to remove CMOS batt as you have done before - do not replace it yet though.Power on the dv7 without the battery in then off by holding down the button until it switches off.Remove AC power hold down power button 5 secs to dissipate power and replace CMOS batt,plug in AC and test.Hopefully it clears the bios settings for you
9/2/2014 7:16:03 AM • HP Pavilion... • Answered on Sep 02, 2014
Display on dv7 1245dx is dim?
Check power settings,display will dim on battery power by default.Settings for display brightness are adjustable for AC and battery power.
9/2/2014 7:07:42 AM • HP Pavilion... • Answered on Sep 02, 2014
Tengo una laptop hp dv7-1245dx,
Dv7-1245 todav?a es un port?til muy agradable.
El procesador se encuentra en su dv7-1245 es el
AMD Turion X2 con tecnolog?a m?vil RM-72 / 2.1 GHz
un reemplazo para ese procesador corre alrededor de $ 190 aqu?
http://www.pcrush.com/product/AMD-Processors/236482/AMD-Turion-X2-RM-72-Dual-core-2.1GHz-Mobile-Processor#product-reviews
o se puede disparar para una actualizaci?n de un 2.4ghz 250 aqu?
http://www.google.com/products/catalog?q=socket+s1+processor&um=1&ie=UTF-8&cid=14671136682080307777&sa=X&ei=vTNvTdOYHoHAtgfl7Jz2Dg&ved=0CCEQ8wIwAg#
Cualquier procesador Socket S1 trabajo en el dv7
Si esto le ayuda a asegurarse de que lo diga:)
4/28/2014 10:01:29 PM • HP Pavilion... • Answered on Apr 28, 2014
My dv7 1245 dx had a short at the ac110 adaptor
Dear Sir/Madam...
You just follow these steps:
1.Remove the battery and Adaptor
2.Press and Hold the On buttun for 30 seconds (without battery/adaptor,this is for reset the BIOS in your Laptop)
3.Now you just connect the adaptor with your laptop
4.On the adaptor socket main switch in main board
5.Watch the Laptop charging Light is ok or not.Also watch the Light in Adaptor is lighting normally or not.if all are normal then try 6th step otherwise problem in your Laptop.Just go for an authorised service center.
6.Try to ON the Laptop
All the Best....
thank you very much By Ganesh(INDIA)
6.
3/28/2014 7:38:43 PM • HP Pavilion... • Answered on Mar 28, 2014
2answers
I have the hp pavilion
Try to connect to an external monitor and see if this give an image. If it does, then the Inverter / backlight or possibly the VDU cable on your laptop is damaged.
If it does not, the issue is most likely a failed graphics chip (common on these models). You CAN get the chip "reballed" but this will cost about £70.00, and not guaranteed to last
1/22/2014 4:46:01 PM • HP Pavilion... • Answered on Jan 22, 2014
Not bleutooz
It can probably be a missing driver issue however you can fix this issue by downloading appropriate driver from your machine`s manufacturer website and then re install it.
10/31/2013 12:22:15 PM • HP Pavilion... • Answered on Oct 31, 2013
HP Pavilion dv7-1245dx Notebook Logo
189 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
mic will not work just signed up skype
  • Computers & Internet
