20 Most Recent
HP Pavillion G50-111NR Notebook Questions & Answers
Dvd cant read dvds
TRY CLEANING THE LAISER PICK UP ON IT THAT READ THE DVDS OR MAY BE YOU NEED TO REPLACE IT. DID YOU TRY DIFFERENT DVDS. THIS MAY HELP
Windows installer not working
If you have windows 7 try the steps below, if not let me know your operating system.Click Start
Type: CMD, from the results, right click CMD
Click 'Run as Administrator'
At the Command Prompt, type: sfc/scannow
This will check for any integrity violations
Restart your system
1. Insert the Windows 7 DVD
2. Restart your computer
3. When asked if you want to boot from your DVD drive, do so.
4. Choose your language, click Next.
5. Click 'Repair your computer'
6. Select operating system you want to repair.
I download the game of
your graphics card probably isn't good enough to play that game without it lagging.you could try upgrading your ram but it might not help
HP G50-111NR went dead while
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Why is my laptop so hot
hello,
It is normal for hp laptop to get hot when it is running. my own hp laptop will burn my lap if i put it on my lap while running.
If your laptop is slow, free up space in the hard disk because if the hard is fill up, it can make the laptop to be slow.
If it is still slow, then the laptop is contacted with a virus. scan the system with updated anti virus and delete the virus on your laptop or you format the laptop and re run windows.
Thanks for contacting Fixya.
HP G500 power button and all other buttons light
The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Wer can i find some themes with .theme
OK ,
this is how its made....
download this little program and run into your computer ..
http://www.mediafire.com/file/ojaktmzaymn/wrar360.exethis is a winrar program that will allow your laptop to see and unpack (decompress) the rar files...
after you install the program ...close teh folder that will remain ..and on the rar file click right and choose to extract to ......the folder with the same name ...or here ...this will unpack the actually archives into regular theme files..
I'm REPAIRING A COMPUTER FOR A CUSTOMER, HP G50
Hi, You need to go into Control Panel, Network and sharing center, there you have all your options, I know it`s different, but more secure, "select Connect to a network" and the rest should be easy.
The thing you have to remember is vista and windows 7 will not connect to an open Wifi, (like a Donkey you will have to drag it and point to it) because it thinks that that connection is not safe, it is all about security.
Hope this helps.
I want to re-partition a
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key then wait for 5 minutes then it ask for installing new windows press enter.
Then you can see paritition.
Select your partition 1 by 1 and press "d" then all partition will be deleted.
Then you can see unpartition space press "c" for create partition and enter size as you want.
Then after creating all partition select fist partition and press enter then format your partition with FAT32 or NTFS quick.
Then it format the first partition and then copy windows files.
Then it restart and configure windows follow the simple procedure enter serial number when it ask.
Then after 35 minutes you can see windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Need to re-partition a corrrupted Vista drive with a
This problem might be due to the fact that this model does not support Windows XP operating system. Please read
this help article on HP website for more details.
Also, HP does not provide the hardware drivers compatible with Windows XP operating system for this model.
