20 Most Recent Konica Minolta magicolor 1690MF All-In-One Laser Printer Questions & Answers
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR: process error - belt (clear by cover) SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended. KONICA MINOLTA SUPPORT PAGE: https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
12/6/2020 2:21:10 AM • Konica Minolta... • Answered on Dec 06, 2020
2answers
Can i reset the drum unit for 1690 mf
Deleting reset Minolta Magicolor 1600W drum / Xerox Phaser 6121 / Oki C110 / Epson C1600 and derivatives identical engine. All the instructions in the link. Can be translated into google. reset-drum-unit-1690-mf-drep1qcu2aclflpmzd1fe3xv-4-0.png Toner do drukarki materiay eksploatacyjne Kasowanie reset bbna Minolta...
8/31/2020 10:01:46 PM • Konica Minolta... • Answered on Aug 31, 2020
3answers
Process error-belt clean by cover-konica minolta 1690mf
replace the belt
5/12/2020 9:30:52 PM • Konica Minolta... • Answered on May 12, 2020
Reset counter
for what counter are you resetting? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/18/2019 12:58:41 PM • Konica Minolta... • Answered on Jun 18, 2019
3answers
I have a Magicolor 1690MF
check paper tray
6/13/2019 9:39:20 PM • Konica Minolta... • Answered on Jun 13, 2019
How do I remove a wad of paper that got jammed on the way out of a Konica Minolta Magicolor 1690mf?
If it got jammed in the fuser unit (the hot part) the fuser can come out as a unit then remove the media wad
3/2/2019 8:06:10 PM • Konica Minolta... • Answered on Mar 02, 2019
2answers
How do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
2/12/2019 7:06:14 AM • Konica Minolta... • Answered on Feb 12, 2019
What does I/C dead mean?
image cartridge for that color y-yellow, c cyan (blue) m magenta (red) k = black replace it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/25/2018 5:49:19 PM • Konica Minolta... • Answered on Mar 25, 2018
I/C LIFE END REPLACE I/C
your drum unit need to be replaced Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 11:34:47 PM • Konica Minolta... • Answered on Mar 10, 2018
Error code 3c10
Sir/Mam, You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/4/2018 8:36:09 PM • Konica Minolta... • Answered on Mar 04, 2018
Error message 0094 after change drum unit
2 transfer roller issue open the located across from the transfer belt sponge looking roller check it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/25/2018 9:57:52 PM • Konica Minolta... • Answered on Feb 25, 2018
How to reset i/c on 1690mf after it has been replaced?
Enter in the service mode,select counter mode and select special parts mode.
8/26/2017 7:57:40 AM • Konica Minolta... • Answered on Aug 26, 2017
I have an error code 0094, and have the service manual went through the check, all working fine apart from changing the printer circuit board, what else could be , any suggestion ? thank you
Code has to deal with 2nd Transfer roller the sponge looking roller across from the transfer belt Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2017 8:19:14 PM • Konica Minolta... • Answered on May 07, 2017
I have a konica minolta 1690mf. paper feed problem error 094
transfer roller issue Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2017 8:16:34 PM • Konica Minolta... • Answered on May 07, 2017
Transfer roller issue. the sponge looking roller across from the transfer belt. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2017 8:16:21 PM • Konica Minolta... • Answered on May 07, 2017
Fuser 1690 mf
7/9/2016 10:07:00 PM • Konica Minolta... • Answered on Jul 09, 2016
Booth room mode
what is Booth room mode?????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/5/2016 1:51:06 AM • Konica Minolta... • Answered on Jul 05, 2016
Firmware won't update on magicolor 1690mf. pc can't find printer
Have a tech come out re-flash the copier OS. Firmware is only available thur secure web site Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/5/2016 12:45:28 AM • Konica Minolta... • Answered on Jul 05, 2016
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
223 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Magicolor Konica Minolta
  • Magicolor Konica Minolta
Most Popular Question
reset drum unit 1690 mf
  • Office Equipment & Supplies
