20 Most Recent
HTC Snap S522 Cell Phone Questions & Answers
How do i block my
i found the answer at
http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Locked samsung sim
You can remove the "Sim lock" error from your phone using unlock code.You can such codes from your phone from
Mobile-Unlocker.com here you need to specify your phone model, country,Network name to which it is locked,IMEI number of your phone.
Unlock code calculator
When Unlocking, always use a unlock code - This method is the simplest and safest method to unlocking your phone. You can hook it up to servers; I would suggest code is if want to pay less (take the risk of trouble) on older models. New phones cannot be unlocked by software.
give your IMEI number & get the unlock code for ur mobile .......... you also get through online..........i will suggest the website
Unlock-Zone.com/ which is doing good service .....you can approach this website.
Niko pls need htc snap pc suite to browse on my
1. Download "ActiveSync" from
this link for Windows XP users or "Mobile Device Center" from
this link for Windows Vista (or above) users.2. Once downloaded, open the file to run it.3. After the Installation is complete, it is best to reboot your computer.4. After Reboot, connect your HTC Snap via its USB cable and "ActiveSync" or "Mobile Device Center" will recognize your new HTC Snap device.Done.
Actually i have a S523.
Hello there, first thing you would want to check is if the speakers are indeed still functional. Now to test that try using the phone to play a multimedia file if the multimedia file plays sound then the units speakers are still functional, and in this case all you have to do is adjust the ringtone to a louder pitch. But if in the process of playing the multimedia files the sounds are not played then the units speakers are bad and would need replacement. Usually replacing the speakers are best done by an expert who would order replacement speakers as well as fit them. The procedure should take less than 3 hours to complete.
Hope this support has been helpful?
Thank you for visiting FixYa.
