20 Most Recent
GE 13.7 cu. ft. / 388 liter Upright Freezer FUF14DPRWH Questions & Answers
High Temp light will not go off even though the
What makes a compressor to run constant is the thermostat. Bang on it to see if it will turn off. turn the setting to 1. if it still wont shut off replace cold control (aka thermostat)
worry about the light later hope this was helpful
Ge feezer model fuf14dtarwh upright. i am getting
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Ge chest freezer wiring diagram
Great question but I cannot answer it. GE makes several models of chest freezers and they are not all wired the same. My eyesight is not to good and I cannot see your freezer so I cannot answer your question. You might try our friend google and look for the make and model of your freezer with the prefix schematic.
10/2/2021 4:24:47 AM •
GE Freezers
Answered
on Oct 02, 2021
Freezer temperature swings
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
8/11/2017 2:07:14 AM •
GE Freezers
Answered
on Aug 11, 2017
