20 Most Recent
Epson EX30 LCD Projector Questions & Answers
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
MY EPSOM PROJECTOR IMAGE IS
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Defective image: one color is
I would say that the lcd panel for that colour is now working in negative mode.
It happens and would require a replacement lcd panel, which is difficult to install and perfectly align without proper jigs.
better to wait till another dead EX30 comes up for sale cheap on ebay and get the whole optics block out of it and do a replacement.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
I have Epson printer workforce pro c5790 shows error 000101, what is the solution for it ?
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head.
Here are some steps you can try to troubleshoot and fix the issue:
- Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
- Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
- Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
- If the error persists after trying the above steps, you may need to replace the print head.
- If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
