20 Most Recent
Canon imageRUNNER 3225 Black and White Copier Questions & Answers
Canon 3225 e280
How remove light Black strips on the paper
Canon IR3225 Copier Machine
1/21/2019 2:04:27 PM •
Canon...
Answered
on Jan 21, 2019
Canon IR 3225 error 0000-191-0000
Error code E000019-0000 is a waste toner full error, in order to get rid of this error you need to remove the waste toner bottle located in the left side of the machine
4/29/2018 7:34:02 AM •
Canon...
Answered
on Apr 29, 2018
How to remove error
E000007 error for fixing film rotation Error
Press *key (Additional Function) then 2 and 8 same time than*key (Additional Function)
you are in service mode
enter in copier
enter in function
enter in clear
touch the Error and touch the ok and power off and on
Error Will clear
2/25/2015 1:10:28 PM •
Canon...
Answered
on Feb 25, 2015
Www.ir 0227 error code what is the problem
Hi
The webpage here:-
Error Codes Canon iR3225 page 3
gives a whole list of error codes, 16 pages in all, but your code I think is on this the third page. Each code can be looked at individually and you can also, for a small charge get a Service Manual (pdf format) for future reference.
Use the arrows at the top of the error list to navigate forwards or backwards through the pages.
Hope this is helpful, if so would you please register that with Fixya
Cheers
2/11/2015 5:51:04 PM •
Canon...
Answered
on Feb 11, 2015
Canon3225 problam e00225canon
Faulty in light intensity of CCD
Disconnect and then connect the flexible cable. Replace the flexible cable,CCD unit or reader controller PCB
12/29/2014 8:09:05 PM •
Canon...
Answered
on Dec 29, 2014
Canon or 3225 problem e0034
E032-0001
Description
The NE controller counter malfunctions.
An open circuit is detected for the count pulse signal.
Remedy
Turn off the main power, and check the cable for an open circuit; then, turn the main power back on.
12/10/2014 5:36:59 AM •
Canon...
Answered
on Dec 10, 2014
The solution for an error code E000733-000
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller PCB.
6/29/2014 10:10:42 AM •
Canon...
Answered
on Jun 29, 2014
