20 Most Recent
Kyocera Copystar CS-2560 Black and White Copier Questions & Answers
Km error code cfb31
firmware update is the only solution sorry about that but you can contact me if you really need the firmware +2560702155632
Kyocera km-2560 c6400 zero cross
To reset this error hit 10871087 this will put the unit in Maint. Mode. Then press 906 then press start.Execute will appear on the screen press it. Either the machine will turn off by itself or it will say on the screen to turn the unit off then on using the power switch on the side of the unit. If the code comes back after all this either the fixing unit or the power supply are bad.
Hope this helps.
Scan not better
scan to email not working... if it was working before... then you need to do a reverse ip lookup or ping your smtp domain name and get it... then enter this instead of the smtp domain name... next make sure that you have the right port number selected... if you are still having issues... lets link up through instant messenger and I will walk you through what needs to be done...
I’m happy to assist further over the phone at
https://www.6ya.com/expert/norman_d2fa496dce30c65d
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
