20 Most Recent Adidas Wooster ADH1768 Watch Questions & Answers
Can't set time on adidas
on the lower right button of your watch is the set button, you have to press and hold it. and in the lower left is the mode button is the mode press it to choose whether you are about to change the flashing digits. the upper right button is start/adv. it is use for adjustment of the flashing digits. i hope this will help you.
7/27/2011 2:16:35 PM • Adidas Wooster... • Answered on Jul 27, 2011
0answers
I can not change the
It appears that this model has been discontinued so that it will not be in their catalogue.
The instruction manual list for Adidas does not list them under models but as descriptions of features.
If you go to http://www.adidas.com/campaigns/watches_fw07/content/performance/pdf/performance_en.pdf and scroll down to the one called "10 lap digital", this seems nearest to the model you have.
Try following the "time setting " instructions. There may be slight differences between models but there a limited number of alternative button sequences available, so it shouldn't take very long to work out the correct alternative if the one given is not quite correct.
10/31/2010 3:55:21 PM • Adidas Wooster... • Answered on Oct 31, 2010
How to set the time on an addidas wooster watch
Put "adidas watches" into your search engine and select the Adidas.com site.
On the screen you will see a menu, select "instructions" and look for your watch in the list of illustrations that are there.
1/13/2010 9:21:44 AM • Adidas Wooster... • Answered on Jan 13, 2010
2answers
I need to know how to set timer for Adidas Ad0297107
There is single manual for all adidas watches. You can find procedure for your watch. ADIDAS-ORIGINALS-TIMEPIECES_CARE-MANUALS_EN.pdf (adidaswatches.com)
12/17/2023 12:01:38 PM • Adidas Watches • Answered on Dec 17, 2023
Adidas ADH 6123. How to set up time and date for my Adidas digital watch please?
It is a basic 4 button watch.
Care Instructions & User Manuals
Adidas Watches https://adidaswatches.com > care-instructions-user-man... Please have a look at the following Care Instructions and User Manuals to get familiar with your watch and ensure correct usage and optimize longevity. Select ...
7/7/2023 11:15:47 PM • Adidas Watches • Answered on Jul 07, 2023
How to setup an Adidas 10-0104 Divers Watch please?
6/24/2023 5:57:50 PM • Adidas Watches • Answered on Jun 24, 2023
I want to replace the band on this Adidas Fortitude watch ADP1709. Do you know where I can purchase this band? thank you
To find a replacement band for your Adidas Fortitude watch model ADP1709, you can check with the manufacturer or an authorized dealer for the specific model. You can also look for compatible replacement bands from third-party retailers or online marketplaces, making sure to verify the fit and quality before making a purchase.
2/14/2023 9:36:23 AM • Adidas Watches • Answered on Feb 14, 2023
My Adidas Archive M1 is blocked
If your Adidas Archive M1 watch is "blocked," it is likely that the watch's movement has stopped working properly. This can happen for a variety of reasons such as a dead battery, a malfunctioning quartz crystal, or a problem with the gears or other internal components. To fix this issue, it is best to take the watch to a qualified watch repair professional who can diagnose and repair the problem. They can determine if the problem is a minor one that can be fixed quickly or if a more extensive repair is needed. Additionally, you can try the following steps:
  • Check the battery: If the watch has a battery, make sure it is still good and replace it if necessary.
  • Check the crown: Make sure the crown (the knob on the side of the watch) is not in the "pulled out" position. If it is, push it back in.
  • Check the time: If the watch has stopped working, try resetting the time and see if that fixes the problem.
It's also a good idea to refer to the manufacturer's manual for troubleshooting steps and warranty information, as some issues may be covered under the warranty.
1/20/2023 10:10:23 AM • Adidas Watches • Answered on Jan 20, 2023
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :- Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
11/7/2018 3:25:32 PM • Adidas Watches • Answered on Nov 07, 2018
I have an adidas adp3190 performance watch. the face says "turn bezel" and has a picture of an arrow in the shape of a circle going counter clockwise. When i turn the bezel it goes black then says R2
Hi, I also have that problem like yours. Is your watch already fixed? Can you please share. Thanks.
7/29/2018 12:28:48 PM • Adidas Watches • Answered on Jul 29, 2018
Adidas Wooster ADH1768 Watch Logo
10 questions posted
Top Adidas Watches Experts
NOEL
NOEL
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Adidas Watch Expert? Answer questions, earn points and help others
View Most Popular
Adidas Watches
  • Adidas Watches
Most Popular Question
39 t set time adidas
  • Watches
