20 Most Recent GE Profile DPSB620ECWW Electric Dryer Questions & Answers
Did u reconnect wires to door switch, or maybe inadvertently pulled them loose.
GE Profile... | Answered on Aug 24, 2017
I would check the door switch. if switch is good, then control board might not be recognizing switch as being closed. Check for proper voltage at the plug. any volts under 208 is bad.
GE Profile... | Answered on Nov 27, 2015
there should be a plug right there
GE Profile... | Answered on Feb 09, 2015
Take the front panel off the bottom and check the big hoses that connect to the drum. From what you are saying, the fan is working but not drawing air through the drum. That is why the light is on because it is not sensing air flow through the connections to the drum.
GE Profile... | Answered on Dec 02, 2013
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
GE Profile... | Answered on Nov 08, 2013
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
GE Profile... | Answered on Dec 01, 2011
did you replace the belt and idler pully and cleaned the fluff from the heater
GE Profile... | Answered on Oct 20, 2011
For a quick inspection, the back is easier to remove to gain sight of the potential problem. Make sure the power is off. You will probably find the drum rubbing somewhere and have to release the weight of the drum to check bearings.
GE Profile... | Answered on Aug 31, 2011
Check the "thermistor" that is on the blower housing for continuity with a multimeter. It should read 2.27k. If you get any other reading, replace it with this part.
Richard Roth
The FixYa Team
GE Profile... | Answered on Aug 14, 2011
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
GE Profile... | Answered on Aug 05, 2011
clean the sensor that is located underneath the lint trap
GE Profile... | Answered on Mar 02, 2011
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
GE Profile... | Answered on Feb 01, 2011
GE Profile DPSB620ECWW Electric Dryer Logo
52 questions posted
Top GE Dryers Experts
John Tripp
John Tripp
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
when turn ge profile dryer makes
  • Dryers
