20 Most Recent GE DBXR463EBWW Electric Dryer Questions & Answers
Timer switch bad. Or door swich
GE DBXR463EBWW... | Answered on Sep 04, 2017
IT'S YOUR DRYER MOTOR,IT'S SO WEAK IT WILL NOT TURN OVER,YOU MIGHT FIND A CHEAP ONE ON EBAY-MIKE
GE DBXR463EBWW... | Answered on Feb 03, 2014
may be heater coil, located inside machine on back right side. unplug dryer, open dryer door and remove screws, with a flat tip screw drive gently pry on each top corner till it pops off, gently move panel forward and disconnect door switch. sit panel aside, lift top all the way up it is clipped on the back so it will not fall off. look to the back and right and the coil looks like a spring, it is easy to change, all you need to do is will the make and model call a appliance store and they can tell the price for a new one. good luck tim
GE DBXR463EBWW... | Answered on Nov 08, 2013
WHAT SIZE IS THE DRIVE BELT FOR THIS DRYER?
GE DBXR463EBWW... | Answered on Feb 18, 2013
Here is the door strike you need to order.
GE DBXR463EBWW... | Answered on Dec 01, 2012
check the timer if working properly.
GE DBXR463EBWW... | Answered on Oct 03, 2012
Either way, plug or dryer cord the white wire goes with the green wire, they are pretty much the same. On the dryer at the block where you are connecting the cord, look just above it and you'll see wires coming into it, the red and black are on the outside, I'm not sure which color on which side but the white and green go in the middle on top one another and the red and black match respectively.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
GE DBXR463EBWW... | Answered on May 18, 2012
GE DBXR463EBWW Electric Dryer Logo
131 questions posted
Top GE Dryers Experts
John Tripp
John Tripp
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
ge dbxr463eboww
  • Dryers
