20 Most Recent Nikon Coolpix P520 Camera - Silver 18.1Mp, 42Xzoom, 24Mm Wide Lens 3.2 Inch Lcd Questions & Answers
for joining files you may have to use a computer.....fade in or fade out is not available in p520....
Nikon Coolpix... | Answered on Dec 07, 2017
we would have no idea if they even know how to use it .
Nikon Coolpix... | Answered on Feb 19, 2017
you need to cut the picture with a program like photoshop, gimp or picasa, and then save it with a different name, or you will overwrite the original picture
Nikon Coolpix... | Answered on Sep 01, 2014
read the manual, or reset the camera
Nikon Coolpix... | Answered on May 25, 2014
upgrade the firmware?
Look in what part of the menu you are. If you are in Automatic scene or effects, you only can change few things. Only when you select P,S,A,M or U, you can set lots of things in he menu. Please look in the manual, because on your camera are so many things you can set, if in the correct menu or in the right settings menu.
Nikon Coolpix... | Answered on Dec 25, 2013
I cant understand your question,please explain your problem clearly
Nikon COOLPIX... | Answered on Jan 08, 2020
Go to Nikon.com and search for your camera and then look for Memory cards that are compatible
Nikon COOLPIX... | Answered on Oct 16, 2019
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
Nikon COOLPIX... | Answered on Sep 24, 2019
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
Nikon COOLPIX... | Answered on Aug 24, 2019
Not sure exactly what the issue is here - could you be more specific please ? Thank you.
Nikon COOLPIX... | Answered on Feb 20, 2019
I would suggest you go to the Nikon support site and see if there is a version you can download from there.
Hi
Here are some suggestions to try and see where the problem may be:
1. Have you tried to charge the battery? We would suggest trying different USB sources (e.g. a USB port on a computer as well as the Nikon supplied AC adapter)
2. Could the battery be dead? If you have tried to charge the battery in the camera via USB then there is a chance the battery is dead and needs replacing. If the camera had not been used for a long time and the battery was stored with little or no charge, the battery may now be un-chargeable.
3. If the camera has been left unused for a long time the internal battery that keeps the time/date may have discharged. You need to be able to set the time/date before the battery can be charged. If you plug the camera into a USB power source and you can see the menu on the LCD then set the date/time.
We hope these suggestions help to get the camera back up and running
Nikon COOLPIX... | Answered on Jan 24, 2019
Nikon Coolpix P520 Camera - Silver 18.1Mp, 42Xzoom, 24Mm Wide Lens 3.2 Inch Lcd Logo
10 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
set up new nikon coolpix p520 now want
  • Cameras
