20 Most Recent GE WHRE5260E Top Load Washer Questions & Answers
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
GE WHRE5260E Top... | Answered on Apr 30, 2015
When the machine agitates, it stops working. The belt has a lot of tension at this point.
stops working?? does it trip shutdown what
your info is far too sparse to make any definitive view
if the belt and rotors gears {egg gear} has failed
you would hear it grinding
so can you hear the motor running
ie youll hear the water circulation motor pump
usually one motor is used for both
if this is the case and the motor runs then its the gear system thats wrong
check the agitator motor start up capacitor hasnt failed
the info you give isnt good enough
GE WHRE5260E Top... | Answered on Feb 09, 2015
I used 2 quartz of Clorox bleach running a full load without clothes. After that the odor has gone for good. Try that.
GE WHRE5260E Top... | Answered on Apr 14, 2014
The water valve is either faulty or clogged. Remove the hoses and check the screen in the water valve on the back of the machine.
GE WHRE5260E Top... | Answered on Feb 05, 2014
You can do one or 2 things. Drain the machine, disconnect the pressure tube going to the level switch and reconnect it. Check the actual switch itself and make sure it is working and also check that it hasnt fallen off and shorted itself against the frame of the washing machine. I see these switches fall off inside a lot.
GE WHRE5260E Top... | Answered on Dec 06, 2013
there should be a key sequence to program the new board as this board will fit a lot of units with different features,and you need to set the program for your particular machine,there should be an instruction sheet on how to accomplish this with the new board
GE WHRE5260E Top... | Answered on Apr 28, 2013
the cloths in the washer needs to be ballance... too much load on one side
GE WHRE5260E Top... | Answered on Jan 01, 2013
Sounds like a broken know try pushing in with some force or pull out with some force if both fail the know will have to be replaced
GE WHRE5260E Top... | Answered on Sep 26, 2012
On a modern washer there will be an Engineers Program which is invoked by a key combination press. You can control all the functions from there and do tests. 1200 rpm is the Ideal speed for a washing machine for good reasons... Ask any Woman this !!
Google your Model with Engineer Program etc.
We have a range of Service Manuals at: www.spotless-service.com and adding many new ones everyday.
GE WHRE5260E Top... | Answered on Aug 29, 2012
easy fix.
replace the motor:
Video
Service guide
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
GE WHRE5260E Top... | Answered on Mar 06, 2012
GE WHRE5260E Top Load Washer Logo
150 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
washing machine water level sensor not
  • Washing Machines
