20 Most Recent GE WSM2700W Unitized Spacemaker Washer and Dryer Questions & Answers
Ge washer wont spin or agitate
The motor is overheating, so the internal thermal protector cuts out. Did you check the start-run capacitor for open circuit? Or it may be breaking down at full voltage. If in doubt, they are fairly cheap to replace. I suggest you try that.
2/2/2018 7:29:34 PM • GE WSM2700W... • Answered on Feb 02, 2018
0answers
How can I remove front panel to replace washer drive belt?
most washers have a back panel to remove or you have to lay them down check and see then let me know
3/12/2016 11:40:41 PM • GE WSM2700W... • Answered on Mar 12, 2016
The dryer will not start.and only hums when you push the start button. Do you think it's the timer
My bet, the drive belt is off or broken. the Hum is probably the drive motor running.
12/22/2014 2:12:01 AM • GE WSM2700W... • Answered on Dec 22, 2014
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer? The pump may be going bad...
7/29/2014 2:41:08 PM • GE WSM2700W... • Answered on Jul 29, 2014
0answers
Had a humming noise from washer it would fill but that was it dryer worked. Replace the capacitor now neither will run. Are the leads the the capacitor reversable both sides were red colored. Could I
Has the breaker tripped? it the doors shut? is there any lights, need to know everything you are seeing and hearing to help.
3/30/2014 10:51:58 AM • GE WSM2700W... • Answered on Mar 30, 2014
0answers
0answers
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
6/10/2013 1:26:53 AM • GE WSM2700W... • Answered on Jun 10, 2013
0answers
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
130 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
ge stackable wsm2700dawww
  • Washing Machines
