20 Most Recent GE WCCB1030 Top Load Washer Questions & Answers
2answers
Timer type
Give your parts distributer your model and serial number and they can get you the proper timer.
12/18/2013 12:58:12 PM • GE WCCB1030 Top... • Answered on Dec 18, 2013
manual
I have a GE commerial
Ive got a couple of the same model. They do agitate slower than previous models a couple of years older. I have gone as far as replacing the motor and got the same results. I can only assume that they are operating as Ge intended.
5/16/2011 1:00:20 AM • GE WCCB1030 Top... • Answered on May 16, 2011
The bolt has come free
You will need to hook something in the hole the bolt was in and pull real hard. the agitator coupler is still in the agitatorif you notice there are plastic fingers around the coupler and you can pry those back a little to aid in your getting the coupler out.
3/26/2011 1:28:46 PM • GE WCCB1030 Top... • Answered on Mar 26, 2011
Makes a loud roaring sound when it switches to the
yes it can be fixed but its not worth it. parts alone are over 200.00 dollars. What that noise is is the bearing in the transmission and it will need to be replaced.
3/26/2011 1:25:07 PM • GE WCCB1030 Top... • Answered on Mar 26, 2011
Having trouble removing the air bell coupling from
I use a 3lb sledge hammer and hit the coupler a couple of times, The coupler will shatter and then you can clean up the shaft and reinstall new coupler
3/26/2011 1:20:38 PM • GE WCCB1030 Top... • Answered on Mar 26, 2011
My washer won't drain or rinse.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Bail and sponge out any water in the machine's tub before removing the pump. Good luck !
9/12/2007 10:19:54 AM • GE WCCB1030 Top... • Answered on Sep 12, 2007
Can I get new brushes for my GE handmixer 56M17
No there’s no brushes for GE handmixer
3/10/2024 8:12:40 PM • GE Washing... • Answered on Mar 10, 2024
GE WSLP1100A0WW not agitating
It sounds like the clutch is slipping https://www.google.com/search?q=GE+WSLP1100A0WW+not+agitating
Top Load Washer - Fills But Will Not Agitate
GE Appliances https://products.geappliances.com > appliance > gea-sup... If the lid switch probe or magnet is missing or damaged, the washer will not agitate or spin, even with the lid closed. Missing: WSLP1100A0WW ‎' Show results with: WSLP1100A0WW
SOLVED: GE WSLP1100A0WW not agitating
Fixya https://www.fixya.com > ... > Washing Machines > GE 17 hours ago - Ge top loader washer agitator does not work To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator.
Ge Washing Machine - Washer Won't Spin Or Agitate
Repair Clinic https://www.repairclinic.com > RepairHelp > Ge-Washe... If a washer is not spinning or agitating, you should first determine if the drive motor is running and if power is reaching the drive motor. If no power if ... ..
3/5/2024 1:09:38 AM • GE Washing... • Answered on Mar 05, 2024
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather Good to see you again. Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely. One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe. ..
2/23/2024 8:08:04 PM • GE Washing... • Answered on Feb 23, 2024
2answers
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
12/11/2023 6:33:13 PM • GE Washing... • Answered on Dec 11, 2023
2answers
GE Washing Machine model GTW330ASK0WW. It won't run, no sounds, display comes on and after 15 seconds shuts down.
Question edited for clarity 'MAKE model (WHAT IT IS)'. You posted to Televisions, moved to GE Washing Machine. It may be the lid lock, test it with your digital multimeter. Look for loose or damaged connections. https://www.google.com/search?q=GE+Gtw330ask0ww+not+running ..
10/21/2023 3:04:17 AM • GE Washing... • Answered on Oct 21, 2023
2answers
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation.
check under agitator possible worn cogs
10/21/2023 3:02:47 AM • GE Washing... • Answered on Oct 21, 2023
2answers
Why wont My ge washer drain
check voltage to pump if ok bad pump also check drain hose
10/21/2023 2:59:12 AM • GE Washing... • Answered on Oct 21, 2023
Ge washer h20 supply error
Check the water level sensor.
10/12/2023 7:52:46 AM • GE Washing... • Answered on Oct 12, 2023
Winterizing a washer in a summer cabin
Just remove the drain hose from the drain upstand pipe and lower it to the floor. It will empty the pump or water.You can also drop a pint of car anti freeze into the machine just to be sure if you wish.
10/10/2023 5:24:57 AM • GE Washing... • Answered on Oct 10, 2023
Why is my GE front load washer breaking the circuit after it starts to fill with water?
You likely have a water leak spraying onto electrics, or the water inlet valve is shorting out.
10/1/2023 3:42:48 AM • GE Washing... • Answered on Oct 01, 2023
GE WCCB1030 Top Load Washer Logo
15 questions posted
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
washer drain or rinse
  • Washing Machines
