My GE profile won't pump out the water, how do I
Most likely you do not need a new pump, just need to clear a blockage in it, which is preventing the pump from running.
Unplug machine, then use a putty knife to push the two retaining clips in, located in the seam between the front panel and the washer's top, about 2 or 3 inches in from each side, while you gently pull the front panel forward. Now, take the hoses off the pump (be ready to catch some water with towels or buckets, depending on how much water is left in the tub) and remove pump. Clean out any obstruction in the pump, like rubber backing from a rug, filling from a pillow, a nail or screw from a pocket, etc. Re-assemble pump and hoses, connect power and test.
