20 Most Recent
GE WCXR1070A Questions & Answers
I am able to wash,
I would focus on the drain pump: the washer will drain before it spins; it will sit there until it drains. Most drain lines have filter baskets to stop large items (coins, rocks, etc.) from getting into the pump. Statt by ensuring it's clear.
1/23/2018 3:33:02 PM •
GE WCXR1070A
Answered
on Jan 23, 2018
GE top loading washer - WCXR1070A 1WW My washing
First try the reset procedure:--And check:---
unplug power cord for half a minute to discharge the circuit board. then plug power cord back in. within the first 90 seconds of restoring power to circuit board, open/close the lid 5 time within 12 second of each. this will reset the circiut board.
If the reset procedure not helping then this no agitate problem is related to:---The motor or the motor fuse.
The fuse is wrapped in the motor harness located along the right side of the cabinet. The fused wire is connected to the C2-3 pin on the inverter. If the fuse is open , the motor would not work.If the motor makes no noise or produces no smoke, I would either suspect a fuse problem or a blown thermal cutout in the motor.
Remove the front panel to locate the the motor on the inverter plate.The inverter board sits on main control board and it cannot be removed.
for motor/inverter board part.click this link:--
http://www.appliancepartspros.com/part_details.aspx?part_id=4368119
for how to disassemble parts Click this link:---
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5213478&diagram_id=25692127#d25692127
also check the belt if it looks worn out or if its very old or if its getting burned out or if its got loose then it has to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep
updated for any more query. You can rate this solution and show your
appreciation
9/23/2010 2:58:34 PM •
GE WCXR1070A
Answered
on Sep 23, 2010
Agitator
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
9/14/2009 4:11:08 PM •
GE WCXR1070A
Answered
on Sep 14, 2009
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
3/21/2009 4:51:57 PM •
GE WCXR1070A
Answered
on Mar 21, 2009
Clothes washer leaking
First of all, check to make sure the drain hose is inserted properly in the drain pipe in your wall. Second, if that's not the problem, check to make sure the drain hoses inside the machine are tightly connected and not cracked. Tighten or replace as necessary.
9/25/2007 3:45:50 PM •
GE WCXR1070A
Answered
on Sep 25, 2007
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather
Good to see you again.
Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely.
One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe.
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
