20 Most Recent
GE WBSE2090A Top Load Washer Questions & Answers
Whirlpool heavy duty washing machine leaking brown oil, worth repairing?
Hello Consumer. We truly apologize for the frustrations you have experienced with your washer. If you would like us to look further into your concerns, please email us directly at
[email protected] . Please include your name, YouTube User ID, complete contact information, the full physical address where the washing machine is located, along with the model and serial numbers. Sincerely, Andre W.
My washer won't fill
If your washing machine was working just fine, and now it won't fill with water or spin, try this first. This is what was wrong with mine, a pressure hose had a clog in the line. First take off the front panal of washer, then connected to the load size dial (small to large load) there will be a clear plastic tube. This tube had what just looked like a stain in it, but in fact it was pluged up and was the whole problem. If the washer already thinks it's full of water, it's not gonna fill or spin..........
I have an older Whirlpool duet that reads sue code.It has water that has not drained fully with a odd sound towards the rear of machine possibly a short in board?
Is it SUE or SUD code?
Sud
SUDS LOCK (Overdose of detergent detected during the wash cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check the Pressure Switch
• Check CCU
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
