20 Most Recent GE S8000E Questions & Answers
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
GE S8000E | Answered on Dec 06, 2017
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
GE S8000E | Answered on Aug 06, 2012
usually crease guard is a combination of hot and cold (warm depending on water temp and water pressures)
Hoover fast wash is generally a shorted time cycle of the normal washes
GE S8000E | Answered on Nov 20, 2009
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
GE S8000E | Answered on Mar 08, 2009
Clean the pump filter and check the pump motor impeller.
It could be any number of things stopping it running. Call a GE Service technician to diagnose and fix.
GE Washing... | Answered on Jan 11, 2020
I have just received my 3rd paycheck which said that $16285 that i have made just in one month by working online over my laptop. This job is amazing and its regular earnings are much better than my regular office job. Join this job now and start making money online easily by just use this link......HER? www.bayusd11.com
If the Fill light is flashing or H2O SUPPLY is scrolling on the display (2015 and newer models): the washer will initiate a 3 or 4 minute lock-out period (depending on model). The washer controls won't respond or change during this time. After 3 or 4 minutes, you can choose your settings and press Start. Unplugging the washer will start the 3 or 4 minute lock-out period again.
GE Washing... | Answered on Jan 09, 2020
GE S8000E Logo
14 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
hoover ca230 1300 special edition
  • Washing Machines
