20 Most Recent Hilti Anchor. HDI 1/2 in. Steel Drop-in Anchors 4-Pack 337954 Questions & Answers
Drop in anchor
What application are you wanting to use it for?
4/10/2019 2:38:43 PM • Hilti Anchor.... • Answered on Apr 10, 2019
4answers
What material needs to be on Wall after drywall
Screws if you have not already used. Then as follows:
Joint compound
Joint tape
Then texture if desired
Primer
Paint
8/17/2021 4:54:04 PM • Drywall • Answered on Aug 17, 2021
Mold on drywall
You need to investigate the cause. Where there is mould, there is damp... If it was through the previous occupiers using things like tumble dryers, irons etc in enclosed spaces without sufficient ventilation then that's one thing. Damp on walls always needs investigating though to ensure the house is structurally sound. Have you had an extended survey done?
4/30/2020 5:26:16 AM • Drywall • Answered on Apr 30, 2020
How can I cut 3/4 inch thick drywall with a dremel cutting disc? cutting drywall pieces from a full sheet to replace on my ceiling and walls. .? cover the dremel with plastic sleeve watch its temp.?
I don't think a Dremel has enough power to do what your after. However there is a larger rotary tool made by several different company's mine is made Dewalt works great fairly inexpensive and will do what you need.
9/30/2019 6:02:04 PM • Drywall • Answered on Sep 30, 2019
4answers
I need help finding a stub behind drywall
The stud finders are not expensive but you can sometimes use a magnet to find the nails. Also you might try shining a flashlight across the wall. The putty put over the nails will sometimes show up. Last resort is to tap on the wall and try and hear the areas that have support under them.
7/19/2019 4:31:44 PM • Drywall • Answered on Jul 19, 2019
4answers
What is the recommended drywall thickness for studs that are 24" apart?
5/8 of an inch is recommended. You may be able to get away with 1/2 inch if you don't really care, but i would check with the building inspector first
7/19/2019 4:30:57 PM • Drywall • Answered on Jul 19, 2019
Is there a tool that will make it easier to cut
Circles are hard to make, I had a lot of trouble when we decided to put recess lighting into the whole house. I wasn't able to find a tool that does all the cutting for you but what worked really well for me was a Goldblatt Drywall Circle Cutter. It doesn't cut all the way through the drywall, it just scores it so that all you have to do is cut from the center of the circle out to the edge and then snap off the pieces. Saves you tons of time trying to get those round edges to look perfect!
7/17/2019 12:17:44 PM • Drywall • Answered on Jul 17, 2019
Hi, Do you need to tape and mud drywall in the kitchen before cabinets are installed?
Not if it isn’t going to show.
10/7/2018 3:44:12 AM • Drywall • Answered on Oct 07, 2018
3answers
When you are drywalling , how do you mark the location of the electric socket ont he drywall yor about to hang in place.
You can either measure up from the floor or the piece of drywall you just hang and then measure over from the wall or the piece of drywall you just hang or you can put the drywall in place and I ball behind it and Mark with a pencil and then cut it out with a dremel tool and you should be good from there. You might want to use a keyhole saw or a roto zip and a Rotozip is the best way to do it but it takes a little practice in order to control it
3/1/2018 5:13:50 AM • Drywall • Answered on Mar 01, 2018
How to fix 1 inch holes in drywall
Wow all those answers are ok but easy way is to wad up a piece of paper larger than the hole-force piece of that paper into hole slowly not to force into cavity behind just slightly flush then stop-take a putty knife and float with drywall compound you can get a small container of that compound at walmart even-then repeat and sand between coats until you are flush and smooth-if there is a texture then on last coat take a roller and run it thru the wet compound
12/17/2017 10:27:47 AM • Drywall • Answered on Dec 17, 2017
How do I hang an object using drywall anchors?
hi there. Sink A Self-Drilling (Threaded) Anchor
  1. Mark your hanging point with a pencil.
  2. Tap the pointed tip of the anchor into the wall with a hammer.
  3. Once the tip is in the drywall, with a screwdriver, screw the anchor in until it's flush to the wall.
Fix-It Friday: Anchors Aweigh! How To Put Anchors Into Walls
womenyoushouldknow.net/fix-it-friday-anchors-aweigh-how-to-put-anchors-into-walls/ How to Install Drywall Anchors to Hang Heavy Stuff on Your Walls How do hang an object using drywall anchors Google Search
11/28/2017 12:55:44 PM • Drywall • Answered on Nov 28, 2017
2answers
How long does it take to hang, tape, mud and finish a sheet of drywall
2 or 3 days, plus or minus depending on how fast the mud dries.
5/2/2017 3:04:17 PM • Drywall • Answered on May 02, 2017
How can I fix tile backer to honeycombed drywall
Get you some heavy duty liquid nail or similar adhesive, put it in strings/loops, wait a bit, put rock on, hold a bit done
4/17/2017 12:39:18 PM • Drywall • Answered on Apr 17, 2017
I have 10000 sqft in drywall how much linear ft is it
Drywall sheets are 4 feet wide. Thus, each foot of a drywall sheet contains 4 square feet. Divide 10,000 by 4 = 2500 linear feet of drywall sheets. Add 5 to 10% for wastage.
3/14/2017 1:39:26 PM • Drywall • Answered on Mar 14, 2017
tip
Cutting Drywall Like a Pro
Cutting drywall is one of the more easy cuttings that you will do when remodeling your house although you hear all kinds of horror stories of people making huge mistakes and having to re-hang drywall or use exorbitant amounts of putty to fix mistakes. Following just a few simple tips you can master the task of cutting drywall. Most of the cuts that you will be doing will fall under the category of score, snap, cut. Because dry wall is fairly easy to cut, for a majority of cuts you will just need a scoring knife with just enough pressure to cut the paper and then you will be able to snap the drywall then you have to cut the paper on the back side and you are done. For the major cutouts that you will be doing like doors and windows, the best way to go about doing them is to measure and cut the boards before you hang them. Its best to have someone help you hold the board in place. There are two main types of saws that you will use a drywall rip saw and a keyhole saw. They each have their purpose and they should only be used for the purposes that they are meant for. The keyhole saw is for small cuts like holes for light fixtures, outlets and switches while the rip saw is for cutting drywall down to size like for doors and windows. Once you have mastered the basics of cutting drywall you will be able to do more advanced home repairs and will spend less time worrying about cutting out pieces of drywall.
on Jan 30, 2016 • Drywall
How is drywall properly installed in a home, the walls and ceilings in kitchens living rooms and bedrooms? Is it just nailed to the studs or does it have to have back on board behind it? But as backer
First, insulation is put in on exterior walls with specific R ratings, drywall is just screwed to studs then spackled.in bathrooms it's a little different. There's different options for material backboard that are waterproof. Some are fiberglass then are finished in resin sealant
5/5/2015 9:56:26 PM • Drywall • Answered on May 05, 2015
2answers
Water damage to ceiling
Cut off the loose make flat tape and drywall mud
3/4/2015 7:34:42 PM • Drywall • Answered on Mar 04, 2015
2answers
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
3/1/2015 2:30:12 AM • Drywall • Answered on Mar 01, 2015
Hilti Anchor. HDI 1/2 in. Steel Drop-in Anchors 4-Pack 337954 Logo
1 questions posted
Top Hilti Drywall Experts
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
NOEL
NOEL
Are you a Hilti Drywall Expert? Answer questions, earn points and help others
View Most Popular
Hilti Drywall
  • Hilti Drywall
Most Popular Question
drop in anchor
  • Drywall
