20 Most Recent
tacoma cover, alternator rear end Questions & Answers
Alternator wiring mixup? Car won't shutoff when started.
Not sure I follow you. The alternator should have a main wire going to the battery, and a plug with 3 wires molded into it. It should be almost impossible to hook it up wrong. I can get you the diagram but I don't know if it will help much.You may need to go to a salvage yard and get a wiring harness to fit the alternator plug. On a 2000 model 4 cyl the red wire goes to the gauges fuse, the yellow wire goes to the warning light, and the small white wire goes to the 7.5amp alternator fuse.
Como se activa la alarma de una toyota tundra
tengo una 2007 toyota tundra lumited 5.7,pero no me dieron el cotrol ,solo la llave y quisiera saber si con solo ka llave podria programar un nuevo control con el mismo sisteme de seguridad que tiene
Car security light won't stop flashing while driving?
Are you disarming the system with a remote or disabling by inserting the key. On some vehicles you may have a remote control key fob and a master key that works with no buttons, it is a straightforward key with no buttons that temporarily disarms the vehicles alarm for use, it does not fully disarm. When the alarm system is armed through the remote it can only be disarmed through the remote via the transmisson of a coded signal. Have you got these 2 different kinds of keys?
Please add detail and resubmit the query
