20 Most Recent Tannoy Mercury MX3-M System Questions & Answers
0answers
What is the best configuration
In audio, beauty is in the ear of the beholder.
If you're NOT bi-amping or bi-wiring them, leave the jumpers on.
Unless you were already stating with junk for electronics there is not a lot of evidence that either of those schemes would result in anything audibly superior, but they WILL cost more due to the expense for extra amplifier channels and boutique speaker wire.
Google it.
4/22/2011 12:50:26 PM • Tannoy Mercury... • Answered on Apr 22, 2011
0answers
3answers
Inverted(puhed in)tweeter
Hi George,
You may be able to pull them out using tape. That is sellotape then gently pull .They should pop out like
a dented car panel. My understanding is these domes really protect moving coil from dust so should not affect sound. Worst case swop the tweeter.
Ive just bought a pair of revolution 3 with same "fault" so I will let you know how I get on .I am in Electronics trade as profession. It may be possible to gently remove dome using a surgical blade then popping out and gluing on with PVA / Latex glue coloured with black ink if you dont like white appearance.
It is sometimes possible to pull out using fine sewing needle push in then gently pull out as if removing a spell from your finger.
Hope this helps
9/24/2010 2:15:53 PM • Tannoy Mercury... • Answered on Sep 24, 2010
Hello, I have the tannoy mercury v1i and I want to replace the tweeter (25 mm (1")) and I do not know how many ohms, how many watts to get for this particular speaker , suggest me please, John
Speaker impedance of 8 ohms suggests home hifi use though the stated performance is typical of a bookshelf speaker, designed to be at the "reasonable" end of the market - reasonable performance, reasonable quality, reasonable cost and suitable for a wide range of volume settings at the lower end of the scale... Constructor catalogues generally offer a wide range of loudspeaker drive units including tweeters and mostly provide pictures. If you want to avoid modifying anything simply choose one that looks like yours and then check the description fits.
2/19/2022 8:48:41 PM • Tannoy Audio... • Answered on Feb 19, 2022
One of my Tannoy R1 speakers fell from about 6 feet high. It landed on its side flat, didn’t really bounce. I hooked it up again, and yeah, sounded like it was at half power and was fuzzy. Looking inside everything looked good, connections were solid, speaker was not ripped or dented. I couldn’t find a fuse, not even sure if there is supposed to be one. What’s the best way to further troubleshoot to fix the damage?
The speakers consist of an induction coil, and a magnet attached to the cone. You have damaged something internally or the cone itself. Speakers don't have fuses unless they are powered speakers with mains input and an amplifier. You need the speaker repaired or replaced. Contact the maker https://www.tannoy.com/service.html Specs https://www.ebay.com/p/78039939 ..
12/20/2020 12:48:51 AM • Tannoy Audio... • Answered on Dec 20, 2020
Dear friends, I cannot get a replacement tweeter for the Tannoy Eyris 2 Sycamore. The company Real Electronics replied that these tweeters are no longer available. Where to order. Thank you, Ctirad.
If the company say they are no longer made, then it's unlikely you will find replacements in any electrical parts supplier. If you still want to use the unit then you will have to look around for one on places like e-bay, which might be faulty elsewhere , but have a working tweeter. A search on e-bay itself might even reveal a spare tweeter! Or a second hand that's cheap to replace the one you have. At least you will another set of spares (except tweeter of course) for the new one!
10/12/2019 9:51:30 PM • Tannoy Audio... • Answered on Oct 12, 2019
Tannoy C-8 speakers serial# 262432, any idea when made?
Two suggestions: They're old how old I can't tell I'd go to their web sight and see what you can find. Sorry that's best I can do.
12/26/2018 4:19:03 PM • Tannoy Audio... • Answered on Dec 26, 2018
I work in a church that has 4 passive speakers across the room, 3 out of 4 of them sound super muffled and n one of them sound perfect Ive tried switching power amps, there is no processing help?
I would say from your description that the tweeters are blown. Can you take the speaker that sounds good and swap it out with one that sounds bad. If you do that and the good one still sounds good. You have a tweeter problem. And they would need to be replaced.
4/3/2015 2:09:19 AM • Tannoy Audio... • Answered on Apr 03, 2015
Tannoy Mercury MX3-M System Logo
8 questions posted
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Tannoy Audio Players & Recorders
Most Popular Question
best configuration
  • Audio Players & Recorders
