20 Most Recent
Casio PATHFINDER ATOMIC SOLAR WATCH PAW1100-1V Questions & Answers
I just bought my casio pathfinder paw 1100 wsatch
http://world.casio.com/wat/download/en/manual/There are so many applications use of the manual will be mandatory.Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.Hope this tip helpsR/Davidhttp://antiqueclock.clockstop.com/
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
