20 Most Recent
Olivetti Lettera 35 L Typewriter Questions & Answers
Olivetti Lettera 35 ribbon
If you have your old spools you can wrap ant 1/2 " ribbon on them if you don't they are difficult to find Gen. ribbon T30 or Nu Kote 53 should work.
DickyO
Loose ribbons, left one doesn't coil the right one's feed
Old Olivettis used a robbon spool that was driven by the turned uver tabs from the ribbon core. Universal replacement ribbons do not have metal cores. If you still have your old spools you can wind the new ribbon on them.
DickyO
HI! MY OLIVETTI LETTERA 32
Is it possible the margins are set closely together? There may be a carriage lock on the bottom l or r side of the carriage.
On my lettera 22 the string that returns the
You can buy a roll of fishing line and make a draw string to match it. Cut a piece off about 14 inch.Tie a knot in one end and a small loop in the other. Hook the loop to the right side and pull it to the left under the carriage. Now wind the mainspring up to about five or six turns and push the small know into the slot. Carefully unwind until string is taught. I’m happy to help further over the phone at
https://www.6ya.com/expert/jayw_0e86fb055a7b73de
I have an Olivetti Lettera
First thing is to be sure the ribbon is feeding, watch while you type. if not you may have a universal spool ribbon that isn't quite that universal. Wind the ribbon onto your old spools.
DickyO
The printer Olivetti ET2500 could
sound like you've got it in delayed print or memory mode, look in the display for the mode it is in. got a book? - look it up. if not STATO OPER is the section of the display (2nd from right) and also the button that changes it (2nd from right, on top right) I couldn't find an English example on the web to look at, just the Italian one.
It needs cleaning. Are there instructions on the
really about the only thing an operater should clean would be the typefaces. I use a pin or needle to carefully remove clumps of ink from typefaces and then use a cloth dampened with alcohol to finish
Where is the serial number located? Also, where
The serial number is located on the right hand side of the machine. It's either on the side of the frame, or just under the the rail. The Owner's Manual ... it's a matter of luck and patience and perseverance. They are around but are very rare.
