20 Most Recent Casio GW330A G Shock Solar Atomic Watch Questions & Answers
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Casio GW330A G... | Answered on Sep 28, 2013
This depends if you want to use the autoreceive mode or not. If you're within an area that you can pick up the signal, it should set itself automatically at 3AM, 4AM and 5AM. You can force it to try and calibrate to the broadcast signal by holding down the receive button while in the "normal" time mode. For best results, put it near a window that faces Colorado (assuming you're in the states) with the top of the watch facing the window.
To turn on or off the autoreceive mode:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Mode button twice so [ON/OFF] Auto is flashing. Press Receive to toggle the mode, then press Adjust twice to set.
If, for whatever reason, you're unable or don't want to use autoset, to manually set:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Adjust button again and 12H/24H will be flashing at the bottom. Press mode again and seconds will be flashing. Mode once more and the hours will be flashing. Use Time Memo/Receive to set it to what you want. Press mode again and minutes flash. Again, use Time Memo/Receive to set it to what you want. Repeat for year, month & day. Press Adjust to finish chaning the time.
Casio GW330A G... | Answered on Mar 18, 2011
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Casio GW330A G... | Answered on Jan 29, 2011
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
Casio GW330A G... | Answered on Apr 20, 2010
http://world.casio.com/wat/download/en/manual/
There are so many aplications use of the manual will be manditory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Casio GW330A G... | Answered on Mar 21, 2010
On the case back usually or user manual
Casio Watches | Answered on Dec 16, 2019
C`mon download manual for make and model of watch as a pdf and read
Casio Watches | Answered on Nov 02, 2019
Download the Casio watch manual pdf and read
depends on your use of watches and the environment you tend to be in. If you are somewhere that allows you to see whether there it is day or night, than using 12 hr setting will work just fine. However if you're in a place that keeps you secluded and you are not able to determine whether it is day or night than 24 hr. setting will help you keep track of not just the time, but whether it is day or night.
Casio Watches | Answered on Sep 30, 2019
Could be poor battery contact
Casio Watches | Answered on Sep 27, 2019
I have one also and number is 612574 so that must be a serial number. have no idea of value.
Casio Watches | Answered on Aug 30, 2019
To set time and date, you must in "Time Keeping Mode" (display day, date & time) then press and hold the left-up button until it start flashing. To set press right-down button, to go next setting press left-down button.
To toggle between 12-hour to 24-hour, again, must in "Time Keeping Mode" then press right-down button.
here is the manual https://support.casio.com/storage/en/manual/pdf/EN/009/qw2672.pdf
Casio Watches | Answered on Aug 19, 2019
Casio GW330A G Shock Solar Atomic Watch Logo
7 questions posted
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
set watch
  • Watches
