20 Most Recent
Minolta DI-2010F Copier Questions & Answers
How do i clear the
Get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. select image clear. TOTAL CLEAR wipes out a lot more last thing to do, try fax clear but will mess with FAX line setting.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I have an error code
Richard, First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Soloutions of Code error C0500 in Di 2010f
Sir/Mam, First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day!!!!!
Di 450 error code c-0210
Right below the drum section is an assemble that has two very fine wires in it. The assemble comes out by pulling it out. have the machine off. When you pull it out you will see to blocks one at each end well those blocks (White Looking) house the connectors for those very thin wires. Several thousand volts travel thru those connectors to the wires to do two things one wire helps transfer the image on to the paper because during the copy/print process the paper goes between both wire and the drum, the second wire prevent the paper from sticking to the drum. After a while with those high voltages going thru those blocks they breakdown and the voltages goes to ground vise the wires causing the machine to issue that code. Might find the those blocks or the whole assy at. the web site below. Open close front door to reset code.
Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at
Di2010f code C004E
Power unit cooling fan is bad or jammed with dust!. looking at the rear of the machine on the right side lower there is a vent. remove the back panel (will require removing the upper back panel also. There is a filter with that motor. it mite be jammed in the fan clean it and tape it to the metal cover or just remove it then will have to check on every once in while. That fan cools the Power supply inside the machine. Might be burn it out worse case the control board that controls it is bad. Btw, I’m available to help over the phone in case u need at
Di 450 earer coad c13f8
Print Head error. The print head is what houses the LASER for printing/copying. Open Close front door to reset. IF not replace the Print head. Worse case the image control board is bad. Also check all connections between the print head and the image control board. Btw, I’m available to help over the phone in case u need at
C-13fa
Sir/Mam, Have C-13F0 in the service manual but no C-13FA
. C-13F0 Has to do with the LASER Inside the Print Head which puts the image on the drum. Might want to have that looked at or the Image control board that controls the Print head. Btw, I’m available to help over the phone in case u need at
C0910 konica di3510
The 2nd Tray Lift motor. Remove draw #2 and check to make sure no paper behind the draw. Secondly REMOVE THE ETRA PAPER IN THE DRAW THE EXTRA SPACE IS NOT FOR SPARE PAPER, it for if you are going to put 11x17 paper in the draw. If these don't work you mite have a burned out 2 tray lift motor. When you close the draw that metal plate at the bottom of the draws goes up Btw, I’m available to help over the phone in case u need at
C0500 error code reset
First ensure the right side cover is closed correctly closed also check that the two latches that on the door are not brock especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole.(Once that is done you can only use that paper clip ever again:) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small " ." will appears when it does press 3. Nothing going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. press it then press trouble reset. Once again will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code you messing with is for the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it. Btw, I’m available to help over the phone in case u need at
