20 Most Recent Minolta EP1083 CS/PRO Copier Questions & Answers
Code maintenance
explain this Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/18/2016 4:19:17 AM • Minolta EP1083... • Answered on Jun 18, 2016
The power trips off anytime it is on
Check the fuser and or the main power board, if you can find a tech with that sysytem a legacy Minolta machine before they became a Konica Minolta. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/9/2016 11:03:16 PM • Minolta EP1083... • Answered on Mar 09, 2016
I have a Minolta EP 1083 the copies that it gives smudge
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
2/29/2016 9:55:10 AM • Minolta EP1083... • Answered on Feb 29, 2016
Dont know if anything is wrong with it, will sell it for cheap
legacy machine can not print with it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 9:14:47 PM • Minolta EP1083... • Answered on Jan 24, 2016
Led rojo encendido al medio del equipo
do not under stand Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 8:45:07 PM • Minolta EP1083... • Answered on Jan 24, 2016
Minolta cs pro ep1054 service manual
12/26/2015 12:55:59 AM • Minolta EP1083... • Answered on Dec 26, 2015
Mi fotocopiadora tira error
Reset button is located behind the copier. Remove the rear upper cover you will see a circuit board with the machine on depress the small black button on the board., lower left If the code comes back then the exposure lamp is bad that is the bright light under the big glass. replace the lamp try this site Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/21/2015 10:10:47 PM • Minolta EP1083... • Answered on Nov 21, 2015
Need a manual for EP 2010 CS/Pro
6/12/2015 8:55:05 PM • Minolta EP1083... • Answered on Jun 12, 2015
Ink fall in down inside minolta cs pro ep
Get the developer replaced. and developer unit cleaned. Have a Konica Minolta tech come out and clean the entire machine replace the required parts such as Developer, clear the counters and run the required F8 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/2/2015 12:23:48 AM • Minolta EP1083... • Answered on Mar 02, 2015
I can not get my
where the black line being left when after the drum or before the fuser THe hot part. make a copy and stop the machine so the paper is in the middle catch it before it goes into the hot part are the lines there? be careful the toner will not be fuse your hand will smear the toner, if the lines are there you need to replace the cleaning blade and maybe the drum and get the image unit that houses the drum might need to be cleaned. if no lines then the fuser is putting the lines on the copy replace the upper and lower fuser rollers and cleaning roller next to the lower fuser roller. try this site as star to get parts. Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 4:39:44 AM • Minolta EP1083... • Answered on Feb 22, 2015
We have Minolta Ep2010, It is showing error cof
There are small sensor under the big glass that look at the size of the document to figure what size it is, well one is bad they look like little bug eye looking up at the glass. replace one or both, try below web site for rough cost if available Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 2:20:58 AM • Minolta EP1083... • Answered on Feb 22, 2015
C0200 on develop
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first wire transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code. web site for parts try below Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 12:30:23 AM • Minolta EP1083... • Answered on Feb 22, 2015
Minolta CS/PRO EP 2030 Copier
Well try the site below and order a drum cleaning blade and developer then once you have that get the service manual for this machine try this site Service manuals electronic components datasheets and equipment schematics... for parts try this Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/21/2015 5:34:32 AM • Minolta EP1083... • Answered on Feb 21, 2015
Error Codes
Well the C0500 code is the code that is given when the fusing unit is bad (THE HOT PART) to reset that code need to go to the rear remove top rear cover and press the small black button on the control board lower left. The C0400 is Exposure Lamp the bright lite under the big glass. Might need to get a new one try web site below as for the C0500 if it comes back do not reset get Konica Minolta rep to look at the fuser unit. IT can catch on fire and that would ruin a perfectly good day. If parts required see the web site below for a start Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/20/2015 1:34:40 AM • Minolta EP1083... • Answered on Feb 20, 2015
EP1054 ERROR C0410
The bright light (Exposure Lamp)under the big glass is having time problems might need to replace it to reset the code remove the upper rear panel with machine on you will see a circuit board on the board a small black switch lower left press to reset. if the code comes back see above try this they mite have it Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 4:07:38 AM • Minolta EP1083... • Answered on Feb 19, 2015
Cs pro ep2030 copier stop and gives a sign message
explain the sign message Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/17/2015 12:54:52 AM • Minolta EP1083... • Answered on Feb 17, 2015
Why are my minolta EP3000 copies very dark all the time?
has the optics been cleaned all the mirrors below the big glass how about the drum and developer has it been replaced? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/15/2015 5:23:25 AM • Minolta EP1083... • Answered on Feb 15, 2015
Error code C04 10
The bright light under the big glass is not working raise the doc feeder or the original cover and press the start button bright light should come on. if not replace the lamp and or the control board. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/14/2015 6:17:01 AM • Minolta EP1083... • Answered on Feb 14, 2015
Minolta cspro 1083 makes gray copy
has the developer been replaced and the required F8 run along with the drum counter reset. Also was the F5 run and F3 all of these F# are run in service mode. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/8/2015 12:00:20 AM • Minolta EP1083... • Answered on Feb 08, 2015
Cspro ep 1085
What about it sir/mam? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/7/2015 11:52:12 PM • Minolta EP1083... • Answered on Feb 07, 2015
111 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
code maintenance
  • Office Equipment & Supplies
