20 Most Recent Craftsman 17762 Wet/Dry Vacuum Questions & Answers
replace the seal. make sure its not trickling down from the hose and that it doesn't have a hairline crack in the lid.
Craftsman 17762... | Answered on May 27, 2014
The filter is for dry pick-up only. Remove it for wet pick-up.
Craftsman 17762... | Answered on Oct 18, 2013
Hi dskordas...
Remove your air filter...you only have to worry about the "floating ball" if you get too much water in your vacuum...it will then **** water into the blower and motor of the vacuum ...not good.
Dump your vacuum and you will have no problem with the water getting too high and causing problems.
Please take time to rate me
Craftsman 17762... | Answered on Sep 18, 2011
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Craftsman 17762... | Answered on Dec 17, 2010
make sure that the filter is cleaned out its most likley dusty
Craftsman 17762... | Answered on Jul 13, 2010
Sears hardware,if you have one near you. Or go onto the internet
Craftsman 17762... | Answered on Apr 16, 2010
are you using a water , foam material filter?
Craftsman 17762... | Answered on Aug 01, 2009
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Craftsman 17762... | Answered on Mar 31, 2009
some filters just pull straight off, while others have a large plastic knob that unscrews to remove the filter. if it is a foam filter, it is just a stretch fit and pulls off, though it usually tears.
J
Craftsman 17762... | Answered on Jun 12, 2008
then it might need a new on/off switch
Craftsman... | Answered on Jun 29, 2019
I don't know exactly but if it has one it will usually be found in intimate contact with the motor.
Some vacs were fitted with a bimetal breaker which is also sited close to the motor, but sometimes there is so much dust around once they open they fail to make a good contact again when the cool and close.
Older vacs weren't fitted with any safety devices.
Craftsman... | Answered on Nov 11, 2017
Yes, you need to take it apart. Maybe ask a friend who knows Mechanics or Electrical.
Craftsman... | Answered on Sep 01, 2017
Most wet dry vacs have a ball float that blocks the vacuum when it is full of liquid. Yours sounds as if it is full or the ball has gotten stuck in the up, or blocking position.
Craftsman... | Answered on Jul 04, 2017
Absolutely yes. If not, the filter will be saturated with water and ruined.
Craftsman... | Answered on Nov 02, 2016
First check if the bag is full. Then check if hose is clogged or attachment is clogged.
Craftsman... | Answered on Mar 06, 2015
Either the bulb blown or not wired right when installed. should have one red wire, one black wire and a ground wire, green or copper.
Craftsman... | Answered on May 27, 2014
Craftsman 17762 Wet/Dry Vacuum Logo
Popular Tags
15 questions posted
Top Craftsman Vacuums Experts
Vernon Taylor
ray gallant
STEVE
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Vacuums
  • Craftsman Vacuums
Most Popular Question
use vacuum water suction
  • Vacuums
