20 Most Recent
Hitachi 0.75 Hex Demolition Hammer Questions & Answers
Hitachi H85
Try just stopping and starting the machine off a while.to see if the hammer appears.
5/3/2014 9:45:25 PM •
Hitachi...
Answered
on May 03, 2014
OIL FOR JACKHAMMERS
There is a sight glass on the side for you to see the oil level. Make sure they are always checked. You can buy the oil at any service center. Hilti makes oil too and can probably be purchased at Home Depots. Also the Home Depots that have tool rental programs would most likely sell the Hitachi oil too.
4/24/2012 6:16:26 AM •
Hitachi...
Answered
on Apr 24, 2012
I have a demolition hammer
For most climates a good oil to use is air compressor oil (mineral). Sold at Lowes and many other stores. It has great lubrication properties and can take good amount of heat. In very cold climates where oil could thicken, store hammer indoors to keep warm until ready to use. Good luck
7/1/2011 8:23:31 PM •
Hitachi...
Answered
on Jul 01, 2011
Hello - I have a Hitachi Demolition Hammer PH-66A.
Hitachi sells a pneumatic oil for use in its air power tools. Your local Hitachi dealer, or any pneumatic dealer will sell the oil. The brand is not as important as using a few drops directly into the air fitting when starting a day of work. If used heavily, oil it again mid way through the working day.
1/26/2010 4:26:24 AM •
Hitachi...
Answered
on Jan 26, 2010
Kango 950 motor runs but hammer only engages sometimes
This is an indication that the hammer needs service. When you take the barrel off you will see the striker. There is a piston inside the striker, when the rubber rings on the piston wear out you have the problem you describe. time to replace the motor brushes clean and regressed, make sure to use the correct grease, Check the backlash on ring and pinions. Don't put too much grease on the piston or it will stick and not strike. Good luck I forgot to ask which version. This is for the uk atlas coco, silver with blue or red handle
5/29/2022 2:06:56 AM •
Hammering
Answered
on May 29, 2022
Where can I get a set of brushes for a kango 950X
Unfortunately, you won't find them - Kango was a great hammer, but the company has been gone for many years and there are no parts available.
I would find a local repair shop that may have a different brand brush that is the same or bigger dimensions - by using a piece of 220 grit sandpaper on a hard, flat surface - you can sand them down to the proper size.
It will get you out of a bind
3/3/2021 2:37:44 PM •
Hammering
Answered
on Mar 03, 2021
Which type of oil for rok demolition hammer thank you
If an oil sight glass is in the modelrange of the brand ROK Rottela 40 , but if no sight glass is used in the model then often is to use special Grease lubrication. or only an special volume of oil and most used of them are zinc-free hydraulic based and included in the manual instructions of a maintenance set (service kit)wear parts set.
5/29/2019 9:53:04 AM •
Hammering
Answered
on May 29, 2019
