20 Most Recent BellSouth 1080 wp (15 Channels) 2-Way Radio Questions & Answers
Where can I get a manual for my Bell South Model
Try Google. Those radios were made for BellSouth by another company and the manuals should be available if you can find out what the company was.
12/4/2017 7:43:00 PM • BellSouth 1080... • Answered on Dec 04, 2017
3answers
I need an owner's manual
phone.manualsonline.com/manuals/mfg/bellsouth/1080_wp_15.html
Just copy and paste this link in your internet address bar to view your manual
12/4/2017 3:44:02 PM • BellSouth 1080... • Answered on Dec 04, 2017
Hello, could you tell me if the BellSouth 1080WP 15 Two-Way Radio is compatible or can communicate effectively with the Bellsouth 2280WP Two-Way radio?
It should. 15 channels = 7 FRS, 8 GMRS. Those are all the frequencies available. The problem could come from setting the "tone" or privacy codes. Make certain those all match and they will talk. The 1080 has 38 privacy codes, I cannot find the 2280. Typically the 22 would mean higher power.
4/12/2014 8:09:59 PM • BellSouth 1080... • Answered on Apr 12, 2014
How do i change the
First you have to remove the belt clip from the bacside of the radio,. Then there is a small clip at the botom of the radio that you snap open in order to remove the back of the radio where the batteries are at.Hope that this hlps
8/2/2013 6:13:11 PM • BellSouth 1080... • Answered on Aug 02, 2013
How to silence the caller button
go to minue button, fine tools, go to volume, turn down caller button.
10/1/2010 12:19:38 AM • BellSouth 1080... • Answered on Oct 01, 2010
I am not able to communicate with a second party
Hi use this link .
(http://www.nowadays.biz/download/2290zwp.pdf)
8/5/2010 1:15:58 PM • BellSouth 1080... • Answered on Aug 05, 2010
I was downloading an article
Please elaborate he problem providing us with more details like the address or link of the website from which you were downloading the article.
Also, let us know the web browser you are using. (Internet Explorer, Firefox, etc.)
Kindly reply to this post with the details. Thanks for using FixYa.
8/5/2010 5:31:00 AM • BellSouth 1080... • Answered on Aug 05, 2010
Where can I download a user guide for a bell south
you cant unless you read oriental language
8/31/2009 3:14:09 AM • BellSouth 1080... • Answered on Aug 31, 2009
Need a user guide
Did you try: [email protected] and ask here? Lots of members here may have this!
8/5/2007 11:34:15 AM • BellSouth 1080... • Answered on Aug 05, 2007
Poor transmission
Its hard to tell exactly whats wrong without some more detail. I am assuming that these are 15 channel FRS walkie talkies? If they are than what you have is 2 FM 2 way radios that operate in the 450 mhz region. FM is usually really clear at both close and far distances. With AM radios its possible for the transimission to be distorted at close distances. First you want to check if this is a transmit problem (tx) or a recieve problem (rx). The easiest way to do this is to listen to other peoples transmissions and see if you can undertand them and if they are clear. Push the monitor button or whatever function there is on that particular radio to turn the squelch off. What you want is to hear static so you will be able to hear other people talking on other handhelds that are using different tones than you or might be too far to break squelch. You want to hear everything. Check how other people transmissions sound..... if they are hard to understand like a transmission from you other handheld does. If the other radios you pic up sound clearer....try using yours again.... but give it some distance... The speakers in these thing are not the best to begin with. Try that out and let me know your results... try to desribe what your hearing in detail.... like "garbled" "distorted" "low audio" stuff like that so I get an idea of what your hearing. Try it out
7/6/2007 6:51:30 PM • BellSouth 1080... • Answered on Jul 06, 2007
Ny bellsouth 1010 walkie talkie are locked, there is A sign of A key in the display And I cannot remove it
The key shown on the display is a "Button Lock". Press and hold the LAMP+ button until the key goes away. Manuals for the 1010 are still available from WOOIL telcom
1/10/2022 11:14:45 PM • BellSouth Radio... • Answered on Jan 10, 2022
2answers
I need a charger for bellsouth 2210 walkie talkie
sorry we do not sell parts here.
3/28/2019 9:30:54 PM • BellSouth Radio... • Answered on Mar 28, 2019
Is the two way radio easily fixed, suspect mic, or is it garbage?
If you can do minor soldering, you may be able to fix the radio. They have no parts available, so they are considered "junk" when they break. But if you do the following, you may be able to repair it: open radio, unscrew the housing and pull it apart. Take the circuit board and look for corrosion, it often looks greenish or white. If the radio has a lot, there is water damage. You may still be able to fix it. You've gone this far! Use a Q Tip dipped in rubbing alcohol and remove as much corrosion as you can. Let it dry. Take your soldering gun and lightly resolder each spot on the circuit board. Touch the tip, as soon as the solder turns liquid, remove it! I have fixedhundreds of radios and cell phones by doing this. But it may not work. It just takes your labor! Good luck!
3/28/2019 8:09:45 PM • BellSouth Radio... • Answered on Mar 28, 2019
My Bellsouth 1010 Wilkie talkies power up fine. Can blow and this transmits fine but talking does not transmit. What am I doing wrong?? I am on the same channel with both.
Please try to have the 2 receivers at least 20-30 ft apart. You may be overloading them if you are too close.
10/8/2018 2:45:51 PM • BellSouth Radio... • Answered on Oct 08, 2018
BellSouth 1080 wp (15 Channels) 2-Way Radio Logo
Popular Tags
14 questions posted
Top BellSouth Radio Communications Experts
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • BellSouth Radio Communications
Most Popular Question
could tell me bellsouth 1080wp 15 two
  • Radio Communications
