20 Most Recent BellSouth 2250BK (22 Channels) 2-Way Radio Questions & Answers
I was abel to make mine work I put one on chanel 20 then scanned with the other and pressed the ptt button on the unit on channel 20 until scanned one found transmition.
BellSouth 2250BK... | Answered on Jan 15, 2014
FRS frequency range: 462.5625 MHz to 467.7125 MHz
GMRS frequency range: 462.5750 MHz to 462.7250 MHz
BellSouth 2250BK... | Answered on Oct 14, 2013
did you put it on the same channel
BellSouth 2250BK... | Answered on Jul 15, 2012
Hold the lamp button ( on the right side), for 2 sec. The symbol will go off.
BellSouth 2250BK... | Answered on May 18, 2011
The manufacturer claims a 2-mile range for these radios, but that is just a pipe dream. These are low power line-of sight radios that are described by many as "toys." Effective range under most conditions is not much more than 100 yards.
Bill B.
BellSouth 2250BK... | Answered on Nov 05, 2010
press and hold the light button on the right side until the key goes away
BellSouth 2250BK... | Answered on Mar 18, 2009
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps.
IT COULD JUST BE FAULTY OUT OF THE BOX THE TRANSMIT SWITCH COULD BE FED VIA A LUGIN RATHER THAN SOLDER CONNECTION AND IN TRANSIT THESE CAN COME LOOSE AND EVEN DISCONNECT COMPLETELY. I ADVISE TAKING THEM BACK FOR AN EXCHANGE SAVE ANY HASSLE.
BellSouth 2250BK... | Answered on Jan 10, 2009
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps. Ed
BellSouth 2250BK... | Answered on Jul 11, 2008
sorry we do not sell parts here.
BellSouth Radio... | Answered on Mar 28, 2019
Please try to have the 2 receivers at least 20-30 ft apart. You may be overloading them if you are too close.
BellSouth Radio... | Answered on Oct 08, 2018
BellSouth 2250BK (22 Channels) 2-Way Radio Logo
Popular Tags
21 questions posted
Top BellSouth Radio Communications Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • BellSouth Radio Communications
Most Popular Question
bell south 2250 one seems voice
  • Radio Communications
