20 Most Recent
BellSouth FW13ZHS (14 Channels) 2-Way Radio Questions & Answers
One watch will not charge
People like me at Fixya don't provide parts for warranty products, but its probably not the battery.
You aren't looking for advice ... but I'll provide a little anyway. Most of the time the customer has unknowingly plugged a charger into an outlet that turns off when the light switch (on the wall) is turned off. So the battery never charges.
12/26/2008 4:27:52 PM •
BellSouth...
Answered
on Dec 26, 2008
BellSouth FW13ZHHS Two Way Raido Instructions
Hello AlBitz,
The Bellsouth FRS radios were actually made by a company called US Electronics. Their branding agreement with Bellsouth ended in 2005 but they are continuing to sell radios that are very similiar to the ones they made under the Bellsouth name. These radios are marketed under the name Xact.
Your best bet to locate a manual for the Bellsouth 1061 radio may be contacting Xact. Their website is located at:
http://www.xactcommunication.com.
Best Regards,
Ken
Go Ahead. Use Us.
5/15/2008 9:19:17 PM •
BellSouth...
Answered
on May 15, 2008
Is the two way radio easily fixed, suspect mic, or is it garbage?
If you can do minor soldering, you may be able to fix the radio. They have no parts available, so they are considered "junk" when they break. But if you do the following, you may be able to repair it: open radio, unscrew the housing and pull it apart. Take the circuit board and look for corrosion, it often looks greenish or white. If the radio has a lot, there is water damage. You may still be able to fix it. You've gone this far! Use a Q Tip dipped in rubbing alcohol and remove as much corrosion as you can. Let it dry. Take your soldering gun and lightly resolder each spot on the circuit board. Touch the tip, as soon as the solder turns liquid, remove it! I have fixedhundreds of radios and cell phones by doing this. But it may not work. It just takes your labor! Good luck!
